Lost 10mpg after EGR clean, etc. Now losing mind!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by FriedCells, Oct 12, 2020.
  1. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Okay, didn't read through all the posts so I apologize if already covered.
    145000 mi overheat
    150000 mi work
    What was the MPG between 145000 mi and 150000 mi?
    Did you try pulling the OCC?
    moto g(7) power ?
  2. douglasjre
    douglasjre Senior Member
    2,177
    717
    Null, NL
    42mpg isn't bad. The most likely cause isn't the battery, it's a clogged egr. When doing repairs for customers I would never clean a part. Parts wear out. Just replace it. Your method leads to pissed off customers and comebacks. Ppl always forget to pay themselves. I love the stories of ppl who bought a car and all it needed was a.... And a...... Labor time shop tools supplies.... It all adds up my friend. Next time replace the egr. Tough advice that doesn't win you over but it's what you needed to hear. I'm sorry
  3. Mendel Leisk
    41,384
    If you’re willing to DIY and have the time, the EGR can be cleaned, to as-new condition, for peanuts. If you’re paying a mechanic, it only makes sense to reuse if you have mechanic do the wrenching but you do the cleaning.
    FriedCells and ASRDogman like this.
  4. FriedCells
    FriedCells Member
    95
    72
    Battered and deep fried! (n)
  5. FriedCells
    FriedCells Member
    95
    72
    I appreciate the advice but after cleaning it, I can't really see why a new EGR cooler would be needed. The EGR cooler is solid metal. There are no 'parts' in it to break. Once I cleaned it, it looked like new, all holes cleared out, spotless. A new one next to it would have looked the same. The only part is the valve, but I checked that as well for smooth operation. So, I can't imagine a new one would be any different. Also used techstream and torque app to monitor and check the function of the valve and it confirms that it is working as expected.
    #105 FriedCells, Dec 30, 2020
  6. FriedCells
    FriedCells Member
    95
    72
    It was always 48-49mpg until the 150K work. Which is what led me to check everything in the world multiple times to no avail. I did remove the OCC for a period of about 4,000 miles to see if it made a difference. No change. Still at 42mpg.
  7. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Its purpose will not improve MPGs.
    #107 Grit, Dec 30, 2020
  8. FriedCells
    FriedCells Member
    95
    72
    Yes, only reason to remove it was in case there was an undetected vacuum leak to the connections of the OCC itself or the connections in the hoses. Just wanted to rule out any issues there as a leak would have affected mpg's.
    TheLastMojojomo and Mendel Leisk like this.
  9. TheLastMojojomo
    TheLastMojojomo Active Member
    232
    181
    US
    SFO likes this.
  10. douglasjre
    2,177
    717
    Null, NL
    Did you clean the hole at the air box and the pipe
  11. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Was wondering about trying a new MAP sensor....
    REVVL V+ 5G ?
  12. KPrius13
    KPrius13 New Member
    I know this is an older thread, I experienced the exact same problem after cleaning out the EGR cooler, EGR valve, intake manifold EGR ports etc etc.. I wanted to post this incase anyone else experienced the same issue. I had removed the plastic EGR cover (2 Philips tip screws) and unthreaded the housing over the valve stem (unscrews counter clockwise) to check that the valve was plunging freely, it ‘looks’ like such a simply device that self adjusts on the threads. But I became suspicious of it after my fuel economy dropped to about 40-42 because it’s the only part of the system I tampered with .. I decided to play around with the unit this morning, I pulled the EGR cover again, ensured everything inside was moving freely and I reinstalled it without threading the housing to the bottom (because it ‘appeared’ to self adjust) and the spring pressure under the housing partially unthreads the unit while you are reinstalling the cap. So I went for a test drive and the engine was misfiring, idling up and down, just running like garbage but it wasn’t throwing a code, took it for a 4 mile spin got about 36 mpg. Pulled the cap off the EGR, threaded it to the bottom of the threads, held it in place with a thin piece of metal so the spring pressure wouldn’t unthread it, then pushed the cap back over removed my tool and tightened it down. Unplugged the battery to reset the calibrations, took it for the same 4 mile route 56mpg. So I took it on a cruise to the grocery store across town, round trip high 50’s again. Average for two shorter round trip is 58 mpg. I will see if this keeps up. But I find it interesting how sensitive this device is in affecting fuel economy. It either needs to be in a specific position if you remove the cover and replace it or may be malfunctioning and need to be replaced all together. Anecdotally It seems to me if it’s not threaded all the way down to near the bottom when the cap goes on that it may hang the valve open or open further than it should, that or the device is malfunctioning. The changes in fuel economy tampering with this device were significant, and the engine running terribly wasn’t even throwing a code. Just thought I’d share for others if they were experiencing something similar.
  13. Mendel Leisk
    41,384
    On my second EGR cleaning I did manage to get the cap off the valve, and when reassembling did similar: there’s a little slot on the base of valve housing; you can restrain the rotating bit (from unwinding upwards) by holding a pin in that slot and against the shaft, as you put the cap back on.
    SFO and jzchen like this.
  14. ChapmanF
    18,123
    It does hang a little bit open at that moment.
    I don't recommend approaching it that way, though, because if you do you are sacrificing a good opportunity to confirm your successful reassembly of the valve.
    Instead, just reassemble the valve the easy way. The pintle will be slightly open when you are done. Put your thumbs on it then and push it closed. It should move easily and smoothly, and you hear a smooth whirrr-tok as the rotor easily spins inside and stops at the ski jump.
    If it doesn't move easily and smoothly, or you hear any sound of scraping or dragging, not a nice whirr and tok at the stop, you know something is amiss.
    Otherwise, you've confirmed it's mechanically ok, and it is now closed.
    SFO, MrPete and jzchen like this.
