Lost 10mpg After Replacing 12V Battery
Discussion in 'Gen 3 Prius Fuel Economy' started by Mike Mayo, Jul 10, 2022.
  1. nicoj36
    nicoj36 Active Member
    518
    162
    In my experience, red line fuel treatment gives the most mpg to the prius. Plus you only need half bottle.
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Throw the other half out in the garbage bin.
    Bill Norton likes this.
  3. Bill Norton
    Bill Norton Senior Member
    2,246
    754
    MONW, Ks.
    2019 Prius
    L Eco
    And you have data to measure this 'difference'? With and without this amazing 'treatment'? Is there a cost benefit to using this 'treatment'?
    Do tell,,, how many 'more mpg' does a 'half a bottle' get you?
    Me? I'm lucky to ever get two tanks to measure that close to each other.
    I guess where I live the temps change, the winds change and my speed may change a bit, but mostly I stick to +5mph the speed limit.
    But my driving isn't always the same old commute.
  4. nicoj36
    518
    162
    Yes the data is on my dashboard. I'll take pics of before/after next time I do a treatment. I only do it once a year, so a bottle (using only half) lasts me 2 years and maintains my mpgs.
  5. Bill Norton
    2,246
    754
    MONW, Ks.
    2019 Prius
    L Eco
    Sounds plausible....
    But you might look up Placebo Effect.
    Could it be the first warm spring week of the year that you pour this elixir in your tank?
    As said, my mpg is always varying. Always.
  6. nicoj36
    518
    162
    I've done fuel treatments during the winter with good results. I understand where you come from though, there are plenty of people who don't believe in fuel systems getting dirty and losing performance.
  7. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    Toyota advertises a product to clean injectors on its Malaysian website. But is it possible that Malaysian fuel is very contaminated?
    08813-80013
    Petrol Injector Cleaner
    #27 MAX2, Apr 24, 2025
  8. Bill Norton
    2,246
    754
    MONW, Ks.
    2019 Prius
    L Eco
    You know, I think you're right. I never use the stuff. Lots of +110k cars in my past. I have a pal that has a few Prii, some that got into the +500k mile range and has never used the stuff.
    Without A -- B testing how do you know what 'results' you claim to be getting by pouring this stuff into you tank once in a while?
  9. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    I use a bottle of fuel system cleaner in my Prius once a year maybe, but I also only use top tier gas stations. It could explain why on my Prius when I did the first EGR cleaning (I forget the miles, 130ish-k) it wasn't clogged at all and looked nothing like the others posted here.
    nicoj36 likes this.
  10. nicoj36
    518
    162
    The mpg indicator on the dash will have higher mpgs.
