Lost All Keys to Prius. Help please
Discussion in 'Gen 3 Prius Accessories and Modifications' started by i32547, Jan 21, 2014.
  1. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    731
    Boulder Hybids, Boulder, CO
    Did you tell sigmabit what version of techstream you're using? different versions have different algorithms. If you can find an older version (5.1 or ealier I think) they use a 6 digit numeric seed, way easier than the 96 digit hex seed + vin requirement....and don't forget drivers door must be open the entire time or reset will fail.
  2. i32547
    i32547 New Member
    paul, the reset process fails before it actually begins...after inputting the 96 digit seed it resounds in failure within 5-10 seconds
    iPhone ?
  3. 3prongpaul
    956
    731
    Sounds like you are doing everything correct. Check all fuses in car, try unhooking 12V in car for a few seconds and reboot laptop??
    Hold on, you don't input 96 digit seed, you input a 6 digit passcode, which is the calculated result from the 96 digit car generated seed.
    You can click on "input to TIS" in order to COPY the seed, but then you need to hit cancel or whatever until you have a valid 6 digit passcode to enter into Techstream....then wait 16 minutes.
  4. i32547
    i32547 New Member
    sorry that's what I meant....the 6 digit code that I receive from sigmabit as a result of sending them the 96 digit
    iPhone ?
  5. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    That is something I wasnt aware of, Is there someone on the forum that is familiar with the smart key computer replacement procedure?
  6. 3prongpaul
    956
    731
    There is no need to swap any hardware if you have Techstream and a valid passcode...unless something in the car is broken which is very unlikely unless it was in a collision.
  7. IMkenNY
    477
    303
    Tropical Buffalo NY
    Four Touring
    I agree, only necessary if the smart key computer is bricked.
    If a ssmart key computer is bricked, can it just be replaced with a unit /fobs from a salvage yard with out any techstream programming?
  8. i32547
    i32547 New Member
    nothing is damaged at all.
    iPhone ?
  9. i32547
    i32547 New Member
    iPhone ?
  10. Mr.Electric
    Mr.Electric Member
    287
    106
    San Francisco
    If you do health check on tech stream the smart ecu should show as white not yellow or white with asterisk. If the smart ecu is not talking ( white with asterisk ) the key programming will surely fail.
  11. andytoyota
    andytoyota New Member
    london
    Hello,
    I did all the steps you did aswell, I looked all over for the bloody keys mine is abit older then yours spoke to the dealer and they said they had to replace ECU etc. for the life of me don't understand how they make a car but can't deal with a lost key.
    Called about 10/20 auto locksmtihs after a day of calling around managed to get my keys done for £400!
    aautolocksmith co uk
  12. Locksmithy
    Locksmithy Junior Member
    Boulder CO
    In the US, ECU only needs to be reset ( by locksmith Eeprom service procedure) or replaced ( by dealer method ) on years 2000-2003. 2004 and newer, we access with scan tool through the OBDII port, reset immobilizer and program Proxii.
  13. Sergio David Moreno
    Sergio David Moreno New Member
    Big Island Hawaii
    its not recommend to use a usb style mongoose cable for reseeds and reprogramming...We always use the tough book only when doing reseeds...Good luck in your quest
  14. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    An old thread though, but what happens, if all keys were lost as in this case? How do you get to put the car in ignition on mode before even programming the smart key fob?
  15. SnowMexicanuck
    56
    66
    Quebec, Canada
    Usually customers get their vehicles towed at our dealer. Not much you can do anyway, when we get the car, we reset the whole system to erase all keys (we need to send a request to at least two people higher up now, request has to be accepted so we that can start the reset) and we register a new master key/remote. From there, it's business as usual to register a new key/remote. Keep in mind that I work in a Toyota dealer, so everything is done with a Techstream.
    Dxta likes this.
  16. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    Sounds expensive.
  17. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Yeah, expensive.
