Lost communication codes U0123 U0124 U0126, HV Battery worries
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by greencycle, Sep 7, 2019.
  1. greencycle
    greencycle New Member
    Bay Area
    Four Touring
    Hey priuschat,
    I was just checking up on my 2008 Touring and found these codes on Techstream. Any ideas where to start troubleshooting? I am just starting to learn so I hope it's not something super obvious...
    I did a Can Bus check that had a bunch of ECUs as not responsive, but that seems to have cleared up after I checked some fuses (they were all fine) - that seems pretty odd, but the ABS/VSC codes are still there as of now.
    Also, I am worried about my HV Battery, Dr. Prius told me I have a poor balance on block #1 of my original HV battery, is there anything I can do about that? It hasn't given me any codes, but it drains fast and I am concerned it may be on its way out sooner rather than later... Any advice on how to source a battery from later model wreck? Am I better off trying to grid charge it or going biting the bullet going OEM before it fails?
    Sorry if this seems a bit scattered, I'm just starting to learn my way through all this stuff! Thanks in advance!
    PriusPaddler likes this.
    49,492
    how many miles on her?
    when you say you were 'just checking', is the car running fine?
  3. greencycle
    Bay Area
    Four Touring
    Currently 127k miles. No lights on dash. As far as I can tell, the car seems to run fine right now other than battery draining to minimum SOC at times on longer trips and that it burns quite a bit of oil.
