Lost Smartkey! Need help
Discussion in 'Gen 3 Prius Main Forum' started by credgar, Nov 17, 2009.
  1. paul sanft
    paul sanft New Member
    I have prius 3g.....no fob slot in dash.....I still have a good fob but want to program another one myself and I found instructions on how to do that if I have the original fob......which I do.....
    Instructions say to insert old fob into slot 2 times etc etc........my question is this: would holding old fob next to power button be be the same as insertion into the slot on other models....if so then I will be able to reprogram a new fob.......PLEASE ANYONE.....ADVISE ON THIS.....THANKS
  2. RobH
    RobH Senior Member
    2,374
    987
    70
    Sunnyvale, California
    Those instructions are for a Gen2. You'll have to get a new, never programmed before keyfob from a dealer or locksmith. Then you'll need a copy of Techstream and the car interface. Search for "mini vci" for more info.
  3. GeXX
    GeXX New Member
    When we lost a key, I called the dealer they wanted the car towed over and such, so I ended up calling pop a lock, came out and cut a new key and programmed all for about $260.. Expensive key, but cheaper and faster than towing it to the dealer and waiting for them to get around to it.
  4. paul sanft
    So I found the mini vci and Techstream software included at $35....
    Just want to confirm that when I get the vci I can then program a smart key fob from my original or from the data in the Prius's brain?
    Thanks in advance for your answer.
  5. DumbMike
    DumbMike Active Member
    560
    119
    Los Angeles
    Did you get a new FOB? If so, you have everything.
    Note that if you lost your other FOBs, you will want to delete them from the car's computer. Unfortunately (or fortunately for me), I didn't have to delete a FOB from the computer so I don't know whether your software can do it. But I can't think of a reason why it wouldn't allow you to delete a lost FOB.
    Mike
