Lost wheel cover, Scraped up wheel on curb
Discussion in 'Gen 3 Prius Main Forum' started by eidling, Jun 25, 2019.
  1. eidling
    eidling Junior Member
    62
    5428C9DF-F127-4CB9-A183-EA1593261C08.jpeg The right side of my car hit/scraped the curb driving to work this morning. Lost one wheel cover and scraped the other. Replacement wheel covers ordered, no problem, but do I need to be concerned that the paint scraped off the wheel itself? Is future rusting something I should be concerned about, or are these wheels or even “rust-able”? Thanks in advance!
  2. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I think you needn't be too worried about alloy wheels rusting, I think I'd be more concerned about the alignment being whacked out, or damage to the tire (…if it was more than just a soft brush). Looks like it was more of a "Close Encounter of the Scuffing Kind", which still might compromise the sidewall cords in the tire! :eek: Keep you eye on it! Good luck! ;)
  3. eidling
    62
    Thank you! Yes, I was wondering about the alignment too. I may have that checked. It drives the same, does not feel like it is pulling, but one never ones, do one? The tires seem fine so far, although I realize there is the possibility of a slow leak. I thought they were alloy wheels, so that's good. Once the new wheel covers are here, it will look as good and bad as it always did! Thanks again for getting back to me.
  4. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    If a magnet sticks, the bare metal will rust without treatment..
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,571
    2,602
    Taylors, SC
    Those are aluminum alloy. They wont rust. If you live in a high road salt area, you might want to scrub them and spray them with a clear spray paint like that sold by Rustoleum. Otherwise, in mild climates, they will be just fine under the wheel cover.
  6. Mendel Leisk
    42,314
    Geez those are sorry looking rims. What a one-two punch Toyo: first you make the alloy rims utilitarian-looking dreck, and cover them with plastic wheel covers. And then, maybe because owners are taking the covers off, you paint them ghetto-black.
    #6 Mendel Leisk, Jun 25, 2019
  7. 2014
    2014 Member
    30
    31
    MA
    Anyone found a good rattle can paint match for these wheels?
  8. Georgina Rudkus
    3,571
    2,602
    Taylors, SC
    I have found Rustoleum black epoxy refrigerator paint to be the most durable and readily available at Lowe's, Home Depot or even Walmart.
    I have painted aluminum parts with it and also a test "coupon" exposed to sunlight and weathering. It is still shiny after 5 plus years of exposure.
    I use it to regularly to paint chassis parts.
    2014 likes this.
  9. eidling
    62
    Other than making them look better, if they won't rust, why do that? We don't usually have a ton of snow, but when we do, the sanders do use salt. Thanks!
  10. eidling
    62
    Well, it looks better with its new cover, but not perfect. My car is in decent, but not perfect condition, so I may just live with it, but would like to consider the possibility of painting the wheel. I'm sure they sell that paint in a spray. Do you they sell it in one of those little touch-up/brush-on versions too? I assume the optimal way would be to sand it and then use a spray. I am not sure I would try painting it with a spray....
    Mick Dave and Mendel Leisk like this.
  11. Mendel Leisk
    42,314
    Toyota should have used the Prius Plug-In rims, or something similar, standard on all 3rd gen with 15" rims. :mad:
    That's what tipped us to get (CDN) "touring", with the nice 17" rims.
    Bay Stater likes this.
  12. Rayman2010
    Rayman2010 Junior Member
    Millheim, Pa.
  13. Tekken
    Tekken Member
    260
    77
    Los Angeles, California
    without wheels cover can effect MPG according to Toyota. is it true?? How many mile different.
  14. Mick Dave
    Mick Dave New Member
    raleigh, nc 27529
    I need a couple because they have fallen off my car recently. Probably due to old age plastic getting brittle and maybe the folks that rotate the tires at the local quick oil change place not being careful. I'm thinking a set like these from wal-mart or what I'd really like is a center cap to just cover the hole in the wheels. Especially if it had a Toyota emblem, but just plane silver or even black would be ok by me. It's actually my daughter's car. I sold it to her when she need one and bought myself a 2022 Corolla hybrid. The Prius got in the mid 50s on my commute but this Corolla is getting like low 60s according to it's calculations. I haven't checked myself but I was really amazed at the difference, especially since it's only rated for mid 50s. Really nice either one for my long commute.
