Lots of warning lights, but no problem?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cm1, Mar 29, 2013.
  1. cm1
    cm1 New Member
    2005 Prius with 144000 miles, all routine and recall service done, 12v battery replaced at 5 years/100k miles. With no apparent change in performance, the following lights illuminated: red triangle, yellow circle with exclamation mark, yellow check engine light on dashboard, and red square with car shape and exclamation mark on display panel. The dealer says the codes - no, I don't know which- indicate a hybrid battery problem, but that Toyota says to reset the lights, drive around for a few days, and see what happens. Problem is, I am supposed to make a 700 mile road trip in a few days and find this to be less than reassuring. Any experience with similar situations? Thanks.
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    Find out what the codes are, pronto. If the traction battery is bad, your 700 mile road trip will almost surely be cut short and you'll be stranded.
  3. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    Corwyn likes this.
  4. Patrick Wong
    18,210
    6,517
    Without knowing the DTC it is hard to comment on your dealer diagnosis.
    I suggest you plan to rent a vehicle for your road trip if it cannot be postponed, since your Prius clearly is not roadworthy at this moment.
  5. cm1
    cm1 New Member
    Thanks everyone. The code is P3000. The 12V seems to be fine, at least when it was checked early today before the performance problems started. The warning lights are back on and the car is losing power, so I will have the battery replaced before making my trip.
    New problem: the battery is under warranty in my home state, but not in my current location. The local dealer states that he cannot honor the warranty. Is there any way of making it possible?
  6. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    There are a few different ways for the P3000 to be set. One is due to the cooling fan not working. There have been recent photos of how badly that fan gets clogged with debris. If you have not cleaned it out since 2005, it *definitely* needs it. In some cases opening the battery and blowing out the dust is indicated also. It's a 1 hour job.
    Dead Hybrid battery? Look for the root cause.. | PriusChat
  7. cm1
    cm1 New Member
    Thanks for the additional insight. I got the new battery, made it home without a glitch, and all is well. Toyota will refund the entire cost - the warranty is nationwide, despite the dealer's protestation otherwise.
  8. Ktay7982
    Ktay7982 Junior Member
    North Carolina
    can anyone help me with my 05 Prius?!
    So... where to begin... I’m like 5 minutes into this chat situation so please forgive me for just sticking this post somewhere....this car had a ton of work done to it in the past month or so. It has 255,000 miles on it, it has a totally brand new hybrid battery cooling fan system (or whatever the correct name is lol) it has no reason to keep giving me the Red Triangle warning light as seen in the picture. I’ve taken it to Toyota and they say it’s fine after keeping it a full day and over night to recheck in the morning time. I’m trying to figure out via YouTube and chats how to reset the red triangle warning light.... I want to see if any other warning lights show up with it this time. Can anyone please help me? Im at my witts end with this car because every other week it’s a different thing. I baby it! It runs so smooth and great I can’t figure out what this warning light is about now. That’s why I want to reset it and see what it does.
    Help
  9. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    Here's a video,
    You need to find out what codes were set, get them from the dealer, post them here for further help.
  10. ChapmanF
    18,992
    If the warning lights keep coming on, there is a problem, you just haven't asked the car what it is yet. (If cars could get frustrated, you'd be driving yours nuts!) A code reader capable of getting all the information from Prius computers, such as Techstream, should be the first stop ... before fiddling with your battery, which will erase the information you need.
    -Chap
    exstudent likes this.
  11. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    The Prius actually must have some AI (Artificial Inteligence) built into it, as it will one day in the very near future just refuse to work, if you continue to drive it, in the current state.
