Loud bang and the rattle highway speed
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 2manycars, Mar 7, 2021.
  1. Leadfoot J. McCoalroller
    8,088
    7,569
    Pennsylvania
    2018 Prius c
    Yes, in the radiator.
    This is why a blown head gasket is so bad. In the cylinder head during combustion, exhaust is created during the BANG phase.
    When the head gasket is breached, some of that exhaust gets blown through the crack or gap where the gasket failed.
    On virtually any piston engine there are four possible destinations for this leak:
    • an oil passage
    • another combustion chamber
    • the outside air
    • the coolant passages.
    That last one is popular. So in many head gasket cases, you get bubbles of freshly-created exhaust in your antifreeze. The water pump will dutifully circulate them, and a few seconds later you have exhaust bubbles in the radiator where a fancy chemical analyzer can positively ID them.
    Merkey likes this.
  2. ASRDogman
    ASRDogman Senior Member
    7,599
    3,916
    I already know this....
    I quote: "The service center used a test that checks for exhaust gases at the radiator."
    Notice the "AT". Not "in"....
    Never had anyone say it banged. 99.9% of the time when a head gasket goes it's slow.
    Unless you have a racing engine....
    #22 ASRDogman, Mar 9, 2021
  3. Leadfoot J. McCoalroller
    8,088
    7,569
    Pennsylvania
    2018 Prius c
    Ah, semantics thing. Fair enough, I guess we will have to let the OP clarify.
    Merkey and ASRDogman like this.
  4. Protec
    Protec Junior Member
    33
    17
    Uk
    Yes, sniff coolant IN the radiator or expansion tank/filler tank with an exhaust emissions analyser.
    It’s better done with the system hot, the analyser will sniff hydrocarbons which, if present is a pretty good indicator of a failed head gasket or other ingress of combustion gases (such as a hairline crack)
  5. ChapmanF
    18,216
    I guess a lot of us just resolved any semantic ambiguity between 'at' and 'in' by applying what we know about how a service center does that test.
  6. ASRDogman
    7,599
    3,916
  7. 2manycars
    2manycars New Member
    Iowa
    I guess I used the "at" from a technical point that you don't actually check the radiator proper, but the overflow tank. My bad.
  8. ASRDogman
    7,599
    3,916
    It's not a big deal, really. Though some really love to beat a dead horse. (y)
  9. ChapmanF
    18,216
    I guess (wham!) checking at that bottle would work (pow!) in a 2012 because in the Gen 3 cooling system (thump!) it's not really an overflow tank but a degas bottle and the fluid (smack!) always circulates through it, so it's the same as what's in the (thud!) radiator.
    In a Gen 1 or Gen 2 (crunch!) it really is an overflow tank, and I'm not sure checking there would be as effective as in the radiator. (Splurtch! eww.)
    Merkey likes this.
