Loud clunk over bumps
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ls6ownerwithaprius, Jun 1, 2022.
  1. Ls6ownerwithaprius
    Ls6ownerwithaprius New Member
    Savannah
    So i have a 2010 with 155k miles... recently it has developed a loud clunk in the front end on bumps ... seeing is how the roads here in tennessee suck so bad im assuming its the struts but im jus looking for a 2nd opinion. It drives fine jus got back from a 14 hour round trip just annoying and i have no problem doing the job myself just wanna make sure before i spend the money
    52,754
    it could also be suspension bushings or worn parts, but certainly the struts likely need replacing at that mileage.
    Ls6ownerwithaprius likes this.
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Struts and links
  4. Paul E. Highway
    Paul E. Highway Active Member
    210
    130
    Hawaii
    Sway bar links will cause a lot of rattles and clunks when they are worn out. Changed links on my 2010 at 149K and the rattles went away. The ends of the links were totally worn and just barely hanging on. Easy job.
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,558
    2,598
    Taylors, SC
    Check all the above. It could be one thing or more that one.
    Some are easier to fix than others.
  6. Ls6ownerwithaprius
    Savannah
    Appreciate it everyone
