loud engine noise, ideas?
Discussion in 'Gen 2 Prius Technical Discussion' started by RyanG, Feb 1, 2018.
  1. RyanG
    RyanG Junior Member
    Chandler, AZ
    Thank you for the advice. I'll pick it up tomorrow and check the fluid. I probably won't have this shop do the work anyway.
    edthefox5 likes this.
  2. RyanG
    RyanG Junior Member
    Chandler, AZ
    I didn't have any WS ATF on hand, so I only took the drain plug off for a second- just enough to look at it and get a spash of fluid (should note that the car was on ramps on at the high end of a slightly sloped driveway). Fluid was very dark, almost like motor oil, and drain plug had a bunch of sludge on it. For the 1/2 cup of fluid that drained out, there were some fairly large pieces of metal on the paper towel.
    The shiny piece in the upper left of the photo is about a cm in length:
    I changed the fluid at 120k a few years ago (Toyota WS). I would not have expected it to look like this already.
    #22 RyanG, Feb 11, 2018
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    That does not look good. Is the trans making noise?
  4. RyanG
    RyanG Junior Member
    Chandler, AZ
    Yes, sir. See post #1 and #7 for videos (not sure how to direct link). It's been a few days but did this on your (and padroo's) advice :)
    Pretty sure the trans is shot.
    SFO likes this.
