Loud Fan Noise on Long Idles
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Jamie L, May 19, 2022.
  1. Jamie L
    Jamie L Junior Member
    alameda, ca
    Hi there, everyone.
    I am currently figuring out if there will any problems to my prius v, 3rd generation, when idling for long periods of time (2 hours). Currently, my child wants to only nap in the car and, as any parent can attest, we are desperate. With that, I want to make sure I don't hurt our car.
    We have done it once and there is a loud fan sound that kicks in relatively frequently, and occasionally an engine running noise. We are running the ac. Is there anything I should be worried about here?
    Thank you in advance for your time!
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Highly UNlikely that there is a problem.
    In "normal" operation, you may have never heard the fan run before.
  3. Air_Boss
    Air_Boss Senior Member
    4,257
    1,195
    New Yawk
    The car will periodically run the ICE to recharge the HV batteries when the electrically driven A/C draws down the HV supply. The A/C fan runs intermittently, especially when the HVAC system runs in closed cabin mode, not having to pre-condition hotter outside air. This is what you and the kiddo are hearing. Nothing to be concerned about.
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,083
    6,944
    Texas Hill Country
    While the car may run properly there are concerns with long idles in a gen3 hybrid. First, I have measured significant thermal cycling of the engine coolant and by definition the engine under these conditions. As much as 50f in just ten minutes. Given this model has head gasket problems, thermal cycling is likely to aggravate that potentially big repair.
    The ac and other systems are running off the high voltage battery until the battery is somewhat discharged. At that point the engine starts in order to charge the hv battery. This cycle will happen several times an hour because the system only partially recharges the hv battery at "idle". Less charge means the hv battery discharges quicker than the initial cycle. When driving the system maintains a more fully charged battery for longer periods.
    Under some conditions there could be a small risk of CO poisoning from exhaust gasses entering the ac air intake.
    Overall its not a good idea, especially because of the thermal cycling.
  5. Jamie L
    alameda, ca
    Thank you for these replies!
  6. bisco
    52,838
    how many miles on her?
  7. BiomedO1
    BiomedO1 Senior Member
    4,584
    2,408
    Left Coast
    You may want to make sure the kiddo's blanket isn't covering the battery cooling fan intake vent. Rear seat, below the cushions. It probably time to take it apart and clean it out. If that vent and fan isn't functioning properly, you'll shorten the life of your traction battery pack.
    Hope this helps..
    Air_Boss likes this.
  8. Jamie L
    alameda, ca
    69k
  9. Jamie L
    alameda, ca
    This is super helpful! I will check it out, thank you.
    bisco and Air_Boss like this.
  10. bisco
    52,838
    i don't see any problem letting the car sit in ready, people camp in them overnight with no known ill effects.
    prius was designed to continually turn the engine on and off to charge the battery, and the battery to run the accessories.
    i agree with rj above, it would be good if you can find a mech who can do a thorough cleaning of your egr circuit, and perhaps add an oil catch can, to help protect your head gasket.
