Loud humming from dr side front
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by kshaggy68, Dec 14, 2019.
  1. kshaggy68
    kshaggy68 New Member
    Cincinnati
    I have a loud bass like humming coming from the front of my 2011 Prius v, speeds under 30 it’s hardly noticeable above that it’s way loud. Something rubbing maybe?
  2. ChapmanF
    15,661
    Does the pitch change with road speed? Making a I - IV - V musical progression as you drive 30, then 40, then 45?
    Can be a bearing (though there would be the same I - IV - V progression with any road-speed-dependent issue, maybe at different pitches).
    49,504
    does it change when you turn? could be tires/bearings/cv joint, how many miles on her?
  4. Richcup1989
    Richcup1989 Junior Member
    Pittsburgh
    Really sounds like a wheel bearing. I have a 2010 Prius with 300k, replaced both front wheel bearing hubs at 250k, was the first real maintenance I’d done other than brakes and tune up
  5. underdog
    underdog Junior Member
    New England
    check the tire pressure. Does the sound change when you put your foot on the brakes?
