Loud metallic slapping sound when driving over lane reflectors - AUDIO RECORDING NOW INCLUDED
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Preeeus, Aug 9, 2016.
  1. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Looking forward to seeing this TSB being posted. Once I have it, I will return to Toyota and ask for the fix to be done once and for all.
  2. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    I also forgot to mention I don't use the wheel covers as I prefer the look of the black OEM wheels over the silver wheel covers.
  3. dorunron
    3,318
    1,105
    Houston, TX
    Have 17" Wheels on this one. Were installed by the Gulf States Toyota Distribution before making it to the dealer.
  4. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    My 2010 has made this noise since it was new.
  5. tweedle99
    tweedle99 Member
    119
    65
    Round Rock, TX
    I had similar problem. After I replaced the front struts, i also noticed "clunking" when I was braille driving or hit a manhole cover. It never did it before the struts.
    I thought it was the end links so I bought 2 new ones. So while taking off the old end links, the front sway bar was disconnected from both sides. This is where i noticed that the sway bar are free to swing up and down, banging on both upper and lower control arm which is the exact sound i heard from inside the car.
    I did replaced both bushings and the sound went sway. The ride was a little softer too.
    See the pix of how worn out the old one is.
    The new bushings will be bigger than the slot but will compress into the spot once you tighten up the bolts.
    Oh, the bushings are designated left and right side.
    Preeeus and Raytheeagle like this.
  6. Preeeus
    Preeeus Member
    258
    60
    Thanks! What bushings are those? Any part # for them?
    Did the old ones fail, did they just wear out, or were the originals a bad design?
  7. Preeeus
    Preeeus Member
    258
    60
    Still working to get this resolved. Vehicle at another Toyota dealership. It's very confusing, time consuming, and tiring dealing with this. The second dealership claims they find nothing wrong, despite the loud noises and the TSB that likely describes this exact issue: T-SB-0136-11
    #47 Preeeus, Aug 12, 2016
  8. tweedle99
    tweedle99 Member
    119
    65
    Round Rock, TX
    The rubber still seems pliable but the notice the hole where the sway bar goes is quite large. I think the bushing supposed to control the up/down motion of the sway bar. After i install the new bushings, the bar had more resistance going up/down.
    These are what i ordered. Cheaper than OE.
    Left
    Right
    Noticed the little nub, it goes into the bracket below
    Preeeus likes this.
  9. Rebound
    Rebound Senior Member
    3,995
    2,643
    Portland, OR
    I might pull my right front brakes and re-grease them tomorrow, to see if this goes away. I doubt it will solve it, but we'll see.
  10. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    Again - I think it's a suspension issue. Sway bar bushings....end links....these can be very noisy when worn, and very inexpensive and easy to replace.
    #50 Jimi1976, Aug 13, 2016
  11. Rebound
    3,995
    2,643
    Portland, OR
    I greased the right front very thoroughly, and the sliders are covered in the stuff. I'll probably wind up contaminating the pads eventually. Sacrificed for science.
    Problem is still there. So lubricating the front brakes is not the solution. And I very recently lubed all of my brake pins and I greased the pad assembly all around anyway.
    To be honest, this problem doesn't bother me. I've had the car four years and only noticed it recently. It's not hard to avoid Dr. Bott's dots.
    Raytheeagle likes this.
  12. Preeeus
    Preeeus Member
    258
    60
    Thanks for performing the experiment!
    Did you check your VIN against the TSB to see if the Slide Pin Bushings need to be replaced?
  13. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    My general observation in life?
    Anyone who brags about having extensive experience and/or how smart they are?
    Usually isn't too bright and knows very little.
  14. dorunron
    3,318
    1,105
    Houston, TX
  15. Preeeus
    Preeeus Member
    258
    60
    We recorded the audio of the loud metallic slapping noises that are generated whenever we drive over lane reflectors.
    Here is the recording: Toyota Prius Loud Slapping Sound when Driving over Lane Refl... - Clyp
    That recording was made with the vehicle driving at about 30 MPH.
    As you can hear, the sound is extremely noticeable and is very loud. When we drive past people, they stare at our Prius, likely thinking it is about to fall apart.
    The Toyota dealership claims this is totally normal and is not indicative of any issue, and therefore does not qualify for any service under the Toyota extended warranty, which is about to expire.
    All feedback is appreciated.
  16. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,518
    Bay Area, California
    2019 Prius Prime
    My 2010 Prius II with 138 k on it does not sound like either audio recordings. Out in Northern California we have all different types of lane reflectors, and no noise like that. Hear plenty of brakes squealing, but that is caused by the quality of drivers:eek:.
    I would not say it is normal, and I do not have that noise eminate from my Prius. IMO, I would inspect the wheels, brakes, rotors and undercarriage myself, or take it to a brake shop as the dealer you have been using I would question.
    Preeeus likes this.
  17. Preeeus
    Preeeus Member
    258
    60
    Thanks Ray. That's an excellent data point.
    It's amazing how the dealership claims it is totally normal.
    Hopefully more people will listen to the audio recording and say whether or not, based on their experiences with the Prius, they think it normal or indicative of a problem.
  18. Jimi1976
    242
    124
    Denver, CO
    Suspension.
    Struts and end links.
    Take it to another dealer
    Preeeus likes this.
  19. Preeeus
    Preeeus Member
    258
    60
    Thanks Jimi.
    Brought it to another Toyota Dealership, using up some valuable miles before the extended warranty expires at 125K.
    They claim everything is normal.
    Not sure what to do. The Toyota extended warranty is only honored at Toyota dealerships, but they claim everything is normal.
    The extended warranty covers (or is supposed to cover) almost all mechanical failures. It seems like something making a loud metallic slapping noise that can be heard a block away is indicative of some sort of mechanical failure.
    Ideas?
  20. Jimi1976
    242
    124
    Denver, CO
    Have you called Toyota of America?
    Have you taken it to a reputable independent shop?
    Preeeus likes this.
