Loud Noise When Turning
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Hailey, Jul 15, 2023.
  1. Hailey
    Hailey Junior Member
    Colorado Springs
    Does anyone know what might be causing a loud noise when I turn the wheel? It happens when I'm parked and moving, too. I've already ruled out wheel bearings and power steering issues.
  2. PriusCamper
    PriusCamper Senior Member
    13,467
    5,434
    Pacific Northwest, USA
    A stethescope or broom handle with one end held to your ear can help you locate the source of the noise. Have someone sit in the driver'ss seat and turn the wheel while you search for the location the noise is coming from.
  3. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    When you turn how many strokes of turn do you have on the wheel until it clunks or half turns they're easier to measure many of you almost at the limit of travel and may not be your steering wheel but it could certainly be inner outer tie rod ends they can clunk things like that so it's further down from the power steering unit It's actually down right behind your engine and transmission sitting kind of low and it runs across the front end from wheeled to wheel The rack assembly I would hope it's not clunking very loud but it could very well be if things are loose enough
  4. Leadfoot J. McCoalroller
    8,290
    7,806
    Pennsylvania
    2018 Prius c
    Can you clarify?
    Does the act of turning the wheel cause the sound, meaning if you just hold the wheel steady in a turn there's no noise?
  5. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Likely a worn intermediate shaft, have you had the recall already?
  6. Hailey
    Colorado Springs
    Yes, the noise only occurs when the wheel is turned. It's a sustained, high pitched whining.
  7. Hailey
    Colorado Springs
    It's not a clunking noise at all, it's more like a long, drawn out, high pitched screeching sound that occurs whenever I turn the wheel.
  8. Hailey
    Colorado Springs
    UPDATE: I fixed the issue. It had a bent dust cover making contact with the brake rotor. Thank you all for the replies!
    ****UPDATE****
  9. PriusCamper
    13,467
    5,434
    Congrats... Those annoying dust covers are always stirring things up... Surprised no one has every tried to replace them with higher quality material that doesn't come loose? I'd love a DIY solution that allowed me to replace all my dust covers next time I work on that part of my car.
