Loud squeak/squeal noise when lifting off the brake pedal
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by egodestruct, Aug 31, 2013.
  1. egodestruct
    egodestruct New Member
    San Diego
    I recently purchased a new (to me) 2010 prius and I've been noticing that sometimes, but not always, I hear a fairly loud noise when lifting my foot off the brake pedal. It sounds like a squeak or squeal, and I want to say I can almost feel a tiny bit of resistance in the pedal when it happens though that could be in my head. The noise does NOT occur when pushing down on the pedal (only when lifting), and it seems to only occur when the car is stopped.
    I also hear what sounds like an electrical pump sound after several pumps of the brake, but I'm not too concerned about that one as that seems like normal pump noise. The squeal definitely seems off to me, however.
    My car is not applicable for the brake accumulator recall (I checked, build date of 5/10).
    Is this noise abnormal? Is it worth taking it in to the dealer?
  2. Former Member 68813
    3,524
    980
    US
    Yes x 2. But only if you are a real poster.
  3. egodestruct
    San Diego
    Ok...?
  4. Former Member 68813
    3,524
    980
    US
    Sometimes new posters post some nonsense here to never come back. Apparently you are not one of them.
  5. egodestruct
    San Diego
    Thought I'd update in case this helps anybody down the road.
    Toyota ended up replacing the brake actuator assembly, which was a $3K job including parts and labor (ouch)! Thankfully, my car is still under warranty so it was covered. I'd be pretty livid if I had to pay that much to fix the brake system.
    Anyways, the groan noise is gone after the replacement.
  6. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,478
    1,548
    Bay Area
    Yeah, there is a recall for the Brake Actuator assembly for 2010 Prius. I guess yours qualify for it.
  7. egodestruct
    San Diego
    That was a recall for the brake accumulator, not the brake actuator. Also my car was not in the affected VIN range (my build date was late 2010).
  8. bisco
    46,661
    glad you were covered, someone else had to go used because of $4,500. quote and out of warranty.
Loading...
