Loud squeaky door/vent opening noise at startup
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Romeo, Sep 20, 2008.
  1. Romeo
    Romeo New Member
    27
    Calgary AB
    There is a lot of threads on different noises but seems nothing on this particular problem – after four months of driving (appx 1000 miles) my Prius started making a loud squeaky door/vent opening noise at the startup somewhere from the back of the rear passenger seat. The noise is quite loud and lasts for about two seconds. It happens only when it is hot outside and when the car was standing under the sun for a few hours. The noise happens at the same time as the usual double-click noise also from the back of the car. There is no squeaky noise when the weather is cold (only the usual double-click). The car seems to be running as usual, but I am sure I have not heard this noise at startup before even on the hottest day. I should probably take it to the dealer, although it’s getting colder up here in Canada and the service might not detect anything. So, I wanted to check with you guys, has anybody had similar problem?
  2. Patrick Wong
    18,210
    6,513
    The double-click noise comes from the system main relays located within the traction battery enclosure. I'm surprised that you can hear them. I cannot hear the relay noise with my 2004 unless the hatch floor is removed.
    Perhaps the other noise is caused by the traction battery ventilation fan? I can't think of any other moving parts back there.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Me too Patrick I don't hear any relay chatter either back yonder. When i first read the vent noise post I immed. thought of the cow moaning noise everyone complains about when you go from outside to inside recirc air on the ac panel. My 07 moans pretty good. Kind of used to it now.But first I've heard of the relay chatter back there.
  4. Romeo
    Romeo New Member
    27
    Calgary AB
    I've read other threads about the double click. Apparently, many other users can hear it. So, I am not too concerned about it. By the way, my hatch floor is half open because of the umbrella stroller that I put under it, so maybe it contributes to it. Anyways, the weather is getting slightly colder and the squeaky noise has gone. So, I think I should be fine for now. Strange that nobody else had the same problem though. There is a lot of Prius owners that live in south and I was hoping that somebody has experienced the same problem.
