loud squeal from engine area when ICE speeds up above idle; noise when car stopped in Park or moving
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by prius4ed, Jan 9, 2011.
  1. prius4ed
    prius4ed Member
    120
    Irvine, CA
    My 2004 Prius makes a loud, consistent SQUEALING NOISE from the engine compartment, only when I increase the ICE RPMs a little by stepping on and holding down the gas pedal. Car is in Park and not moving (it also happens when car is driving, and ICE revs above idle). It sounds like either something rubbing, a bad bearing, or a vacuum leak. I looked everywhere. I removed the serpentine belt and the noise still happened when the ICE is sped up, so it's not an idler bearing, the waterpump, the belt, or anything driven by the belt. I changed the engine oil. The transaxle oil looks dark red but clear. Someone said it may be the MG1 or MG2 bearings. Others say vacuum leak. It is really loud and sounds like it's from everywhere -- engine and transaxle and electric motor and inverter. It does not happen when the ICE is off, or idling. Any suggestions would be great.
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Re: loud squeal from engine area when ICE speeds up above idle; noise when car stopped in Park or mo
    How many miles on the car, and how many miles on your trans fluid? Do you get this noise in stealth mode?
    If it is the engine or transmission, then you might as well drive it until it dies. Neither is economically rebuildable. Salvage engines are abundant and cheap. Transaxles less so. If it was a vac leak making that much noise you'd probably have check engine light on.
  3. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    I would think it is the water pump drive belt slipping. It must drive something else as well? Check and see if it is loss or ready to break. Hal
  4. NCExec
    NCExec Toyota Import Hybrid Owner
    Scotland, UK
    Hi from a Newbie!
    If your noise is the same as the one I have been experiencing on my Toyota Estima E-Four Hybrid then I suggest that you pay it some serious attention.
    I have been hearing a squeal on startup until the engine has warmed up and the HV batteries are stabilised again, just before the MPV changes over to Electric, for some 3 months now.
    I use the "Previa" in the UK as a private taxi, bought it 3 years ago, fully maintain it - foolishly listening to the dealers and Toyota regarding the transmission fluid - and had a short vibrant spell of a couple of minutes followed by a complete drive failure!!!!!!!!!
    My local dealer that I trust, as far as I must, is trying to tell me that it is a gearbox failure and looking into getting the vehicle back on the road for me.
    I had to tow the vehicle a couple of miles, very carefully and slowly with the engine running and in neutral, so I obtained a few OBD2 fault codes, but they do not directly indicate the fault that they are advising me of.
    P3103, P1820, C1213, C1311, C1313, C1364 and shorting out pins 4 and 13 on the Diagnostics plug produced a 51 and 58 code.
    I replaced a melted 10amp "Dome" fuse which cleared all of the 51 and 58 faults and rolled the vehicle onto a trailer for the 27 mile trip (n.b. I am in Scotland, UK)
    Toyoa reports fault codes P3000, P3101 and P3120 and are advising me that the gearbox is suspect.
    Sorry if I am hijacking your thread a bit but the above details and prospective expense frightens me and if yo are heading the same way should seriously concern you!
    Norrie, CCNA, CompTIA A+/Network+, Scotland UK.
  5. prius4ed
    prius4ed Member
    120
    Irvine, CA
    thanks for everyone's replies. I drove the car today, paying more attention to the noise. It does NOT happen in stealth mode. It does not happen when the ICE idling. It DOES NOT seem to happen when the ICE is increasing from an idle speed (such as when I floor the pedal to accelerate the car) but it DOES happen when the ICE is HOLDING AT A HIGHER RPM or SLOWING DOWN IT'S SPEED. It is a high pitched squeal. I am starting to think it's a vacuum leak from the engine or some vacuum device, rather than a bad bearing. For the most part, while I'm cruising on the highway, I don't hear it. I hear it most when I'm driving around town, and the noise happens when the ICE is slowing down from a faster speed. I hear it when I'm in Park and I step on the gas pedal to speed up the ICE. The noise will continue constantly when I hold the gas pedal half way down to keep the ICE spinning at above idle. Anyone know what to look for that only leaks vacuum when the ICE is above idle or slowing down? I may try tightening the intake manifold and throttle body bolts tomorrow. I can't find any loose vacuum lines, but there are so many.
  6. prius4ed
    prius4ed Member
    120
    Irvine, CA
    Anyone have the vacuum diagram for the engine compartment?
  7. prius4ed
    prius4ed Member
    120
    Irvine, CA
    Forgot to say, car has 19k miles (2004 Prius), and was in a front end accident. I replaced the hood, fenders, inverter, inverter pump, left front brake line, brake fluid reservoir, radiator, radiator fans, air bags, seatbelts. I bought it after the accident, and don't know if the seller replaced other things. Also, what does fresh ATF-WS look like? My fluid is dark red, and non transparent. I put some into a plastic bottle and you can only see light through it if you slosh it around inside the bottle so that only a thin layer is on the bottle. I am wondering if worn trans fluid can cause the noise, but I'd like someone to tell me this noise has nothing to do with the transaxle (based on it happening when car is stopped).
  8. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    The fact that there is no noise in stealth is a good sign, meaning its most likely isolated to the engine. A collision hard enough to deploy airbags means any number of odd things could have happened. I was just wondering if some kind of crack in the air intake could cause a high pitched whistling noise. You could pop the top off the air intake, pull the air filter, and run it for a few minutes to see if it still makes the noise. It may be pretty tough to track this one down. But, if you've changed transaxle fluid, and your MPG is good, and there are no codes, then it is really hard to imagine that there is anything else that you can do now that will prevent a big repair bill later.
  9. prius4ed
    prius4ed Member
    120
    Irvine, CA
    Loud Squeal Problem Solved - just wanted to close this issue in case someone later on has a similar problem. The loud squeal from the ICE area was caused by tiny cracks in the intake manifold mounting flange, which were caused by the front end accident which pushed the radiator fan into the Throttle body, cracking only the Throttle position motor casing. Enough force to crack the intake manifold flange at 2 of the mounting bolts, which allowed vacuum to escape at the flange/cylinder head interface while the ICE was running only at certain speeds and conditions (highest vacuum level, I guess). Thanks for everyone's help, advice. Special thanks to Patrick Wong.
    2 people like this.
  10. Patrick Wong
    18,199
    6,464
    How about a few photos showing the damaged area?
    Did you replace the intake manifold and throttle body? If so, what was your source and cost?
  11. prius4ed
    prius4ed Member
    120
    Irvine, CA
    Hi Patrick, thanks for the inquiry. I took some photos of the intake manifold overall, just to document what things looked like so I can refer to photos during reassy. I didn't take any close up photos of the cracks in the intake manifold, because they were barely perceptible and my cell phone camera does not take good macro photos. Basically, the front end accident applied a downward force against the intake manifold, which stressed the manifold mounting flanges near the bolts. There were microcracks in the flanges between the bolts, not through any intake runners. But because the cracks went all the way through the flange, the bolts no longer applied uniform clamping pressure across the flange between bolts. Result was air leaking loudly into runners under certain engine loading conditions - drove me nuts to find this. I used silicone sealant on both sides of the intake gasket (cleaned all head, gasket and manifold surfaces first) and larger washers under the intake bolts to distribute the clamping force better; problem solved. The throttle body was also damaged during the accident; I bought a used one from car-parts.com for about $50. The prices from carparts.com are great but sometimes you get junky parts.
  12. prius4ed
    prius4ed Member
    120
    Irvine, CA
    I got most of the parts to repair my Prius from www.car-parts.com really cheaply. The used throttle body was about $50. For the intake manifold, I simply used a 1/8-inch thick washer under each mounting flange bolt, near the cracks, as the cracks were not conducive to the intake runners; they were just in the flanges which caused loss of clamping pressure at the intake gasket. Works like a charm. I took some photos but can't see the cracks in them, sorry.
  13. Fuad
    Fuad New Member
    Hi I have the estima E Four Hybrid as well ad have some problem , did you get your sorted , How can I contact you or speak to you directly please
    Hi from a Newbie!
    Norrie, CCNA, CompTIA A+/Network+, Scotland UK.[/quote]
  14. Fuad
    Fuad New Member
