Loud thudding sound at idle
Discussion in 'Gen 2 Prius Technical Discussion' started by Banksy, Sep 16, 2020.
  1. Banksy
    Banksy Active Member
    415
    133
    Lancaster Pennsylvania
    Was just driving down the high way and noticed a vibration/ hesitation when accelerating
    At idle there is a loud thudding sound that's going on.
    I don't have any codes pilling yet
    Seems to be coming from the drivers side.
    Any ideas?
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Any warning lights presented on the dash?
  3. Banksy
    415
    133
    None
    When accelerating I can feel a lot of hesitation and a powerful vibration
    There is oil in this car just checked
    Also the engine seems to be wanting to shut down immediately at idle.
    Really confused here and concerned
    52,738
    what exactly is 'idle' on a prius?
    edthefox5 likes this.
  5. Banksy
    415
    133
    P0300 P0303. P0304
    All misfires
  6. Banksy
    415
    133
    Also just changed the oil like 500 miles ago.
    Has a new MAF
    Never did plugs on this car
  7. Banksy
    415
    133
    That's pretty funny dude
  8. bisco
    52,738
    seriously, is that engine at idle, or engine off?
  9. Banksy
    415
    133
    Idle
    It'll idle for a few seconds then shut off
  10. bisco
    52,738
    maybe a loose heat shield or aero cover, can you get her on a lift?
  11. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Depending on the SOC this could be normal.
    Check the plugs, you might have oil leaking into the wells from the valve cover. How many miles on the plugs and injectors?
    Do you have techstream up and running?
  12. Banksy
    415
    133
    So I do have techstream I literally just got home.
    As for how old the plugs injectors and coils are I have absolutely no idea.
    I got this car at 250k did the trans axel fluid and HV battery and that's it. Knew I should have done plugs... Oh well.
    I have a set of plugs and coils on the way
    I am curious if this is the injectors
    Is there a way to test that in techstream?
    I'd like to see the resistance the injectors are putting out and see if it's in spec
    Is it likely this could be a timing or head gasket issue?
    I don't have access to a lift but this is definitely an ICE issue
    Cylinder 3 and four are misfires from what OBD is telling me on techstream. Only looked at it on techstream for a minute or so.
    Just find it very odd that two coils or plugs went out at the same time. Car probably needed these anyway but I got a feeling this is going to end up being something else
    #12 Banksy, Sep 16, 2020
  13. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Be careful buying plugs online, as there have been numerous counterfeits reported.
    Did you inspect the plugs for carbon tracking or oil fouling already?
    You can use TS to look at the short and long fuel trims. Are you using top tier fuel or a PEA additive?
  14. Banksy
    415
    133
    Got some NDK iridium plugs
    As for inspection of oil I haven't pulled the plugs yet. Or coils for that matter.
    However I probably will tomorrow. Might be the valve cover gasket you're right that's a pretty solid possibility.
  15. Banksy
    415
    133
    Ok so didn't know that the plugs were so tiny my regular plug wrench can't get into the wells
    However I have one due in tomorrow
    I did pull the coils off cylinder at far left and far right am assuming one on the right is four.
    I didn't see any oil on either coil. However I did notice what looked like some white powder like residue on the end of the coil. I'm guessing this is corrosion.
    Like I said I'm not seeing any oil on these coils as of yet doesn't mean there isn't any on the plugs however I can't know that until I get a plug socket it
    Apparently 16mm is a really weird size and all my local parts stores don't have them
  16. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Don't have a 5/8" spark plug socket handy?
  17. Banksy
    415
    133
    No I don't my one I use for my other cars doesnt fit
  18. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    5/8" should be readily available just about anywhere, and way less expensive.
    jerrymildred likes this.
  19. Banksy
    415
    133
    Oh well when I called auto zone that's what they told me. I'll have one in tomorrow and go from there.
  20. dolj
    dolj Senior Member
    8,632
    4,385
    Wellington, New Zealand
    The plugs are 5/8" and is what you need. One of the few things that metrication never converted. A 16mm plug socket will probably work but will be sloppy as 5/8" = 15.875mm, so just get the easily available 5/8" size.
