Loud thudding sound at idle
Discussion in 'Gen 2 Prius Technical Discussion' started by Banksy, Sep 16, 2020.
  1. Banksy
    Banksy Active Member
    415
    133
    Lancaster Pennsylvania
    Alright pulled the plugs
    These things are shot like really bad
    Looks like part of the plug at the bottom broke off
    Should I try to suck out any debris with a vaccine through the plug well?
    52,739
    yes, or remove the head if you can't get it out. or maybe not. a closer look at the pic doesn't look like anything fell off but burned off.
  3. Banksy
    415
    133
    You think that ceramic burnt off?
    52,739
    i thought the ceramic was the other end?
  5. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Looks like a clean crack from this angle, but that image is deceiving.
    You could save some time with a cheap borescope, some are under $20.
    Raytheeagle, jerrymildred and bisco like this.
  6. bisco
    52,739
    ah, i see it now
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    I don't have a borescope yet. Oddly enough, I've never needed one. But if I pulled out a spark plug that looked like that, I'd be out buying a borescope right away. It may be that the broken off ceramic has already been beat to dust and done all the cylinder wall damage it's going to do, but I would want to be sure before running it again.
  8. dolj
    dolj Senior Member
    8,632
    4,385
    Wellington, New Zealand
    Is the Iridium disc still attached to the electrode (underside - can't see in the image)?
  9. Banksy
    415
    133
    Here is a picture of inside via a bit scope
    Definitely something in there
    Tried to get a chop stick in there to see if it was loose or embedded
    Definitely not embedded
    Perhaps some grease on the end of a chopstick to fish it out?
  10. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    That piece doesn't look that big. Would give the old greasy stick trick a shot, wonder if vaseline is sticky enough.
    Might try hooking up a smaller diameter plastic/rubber hose or a larger diameter straw (with an angle cut tip) to a vacuum.
    They offer straws in metal, glass, silicon, plastic, and bamboo. If using the metal variety you could fish it out with a magnet if needed.
    Some can be quite long, others end around 8.5".
    They make mini / micro vacuum attachments, which could be an option as well if not to large in diameter.
  11. Banksy
    415
    133
    Alright sucked out the broken piece with a vacuum and piece of fuel line
    Changed plugs and coils
    Works awesome
    Thanks for the help!
    Would anyone recommend a brand of coils for the future? I got these off Amazon in a pinch because oem coils at auto zone were like 95 each
    Any solid offerings that'll work well long term in the future?
    SFO likes this.
  12. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    Glad you got it fixed. If I want to replace a part once and be done then it's OEM or Denso (which makes alot of parts for OEM).
