Loud Whine from car when heat is first turned on
Discussion in 'Gen 2 Prius Main Forum' started by Tevin, Nov 30, 2018.
  1. Tevin
    Tevin New Member
    Lynchburg, VA
    Hello All,
    I have a 2005 Prius and three days ago i noticed that when i turn on the heat, the car makes a loud noise under the hood, goes away, makes the noise, goes away and does it one more time and doesn't do it anymore unless the car is turned off and restarted with the heat on. I'm not really sure what this is... fyi the car just hit 265,000 miles last weekend.
    52,841
    maybe the 3 way coolant valve?
  3. Tevin
    Tevin New Member
    Lynchburg, VA
    I'm going in for a oil change at dealer tomorrow, i guess i could just check with them. my Maint. Required light is the only one on
    52,841
    havoc damper/motor another suspect
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Open the hood and see whats making the noise.
    kenoarto likes this.
  6. ChapmanF
    19,016
    Use the Air Conditioning active tests in Techstream to turn on and off the individual bits of the system one at a time, and note which one makes a loud noise under the hood.
    -Chap
    Skibob likes this.
