Louder than normal noise under hood when running AC
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NWDiedrich, Jun 21, 2016.
  1. NWDiedrich
    NWDiedrich Junior Member
    32
    Grand Rapids, Michigan
    Good to know that the sound level is likely normal. Thanks all.
    52,862
    pleasure.
  3. Tideland Prius
    16,681
    I ran Remote A/C twice last Sunday because of this thread (I usually just rely on the SPVS) to check out the sound.
    1. In the morning, I ran it. It was soft and non-intrusive. But then, it was 9am and not particularly hot yet. The interior was mild when I got in but you could tell the A/C ran because it had that distinctive A/C smell
    2. I ran it again in the afternoon after about 1 hour of parking (partially in the shade as the sun rotated and the tree provided partial shade to the rear of the car). It was LOUD. It's of course warmer in the afternoon so the A/C ran harder.
    So yeah, it can be soft or it can be loud depending on outside temperature, interior temperature, and your set temperature for the climate control. Oh and I was in ECO mode if that matters but I've actually never tested to see if the A/C runs in ECO mode if you are in ECO mode or whether it just runs at full blast to cool the interior.
  4. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    it runs slightly slower in eco mode/
  5. CR94
    CR94 Senior Member
    2,831
    1,243
    Northwestern S.C.
    I'm hoping that makes the hyperexpensive compressor last longer.
  6. ChapmanF
    19,027
    Caught mine the other day running 2250 watts briefly after being parked in hot sun. I guess I don't know exactly what the maximum possible is.
    So it's not just a matter of it can sometimes run a little harder than other times ... the controller has (nearly at least) a full factor-of-ten range of power levels to tell the compressor to run at, depending on temperatures, humidity, fan speed, your temp setting, and eco setting.
    Naturally it doesn't sound the same when it's loafing along at 1/3 HP as it does when putting out 3 HP.
    -Chap
    Tideland Prius likes this.
  7. yeldogt
    yeldogt Active Member
    810
    313
    NE
    I notice the compressor noise on mine (11x 2 Prius/ 16 CT). They tend to run hard for about 15 seconds .. then the noise goes away until it cycles again ... I head it today while sitting in the sun .. parked.
