Lousy computer readings are bogus
Discussion in 'Gen 2 Prius Fuel Economy' started by sl7vk, Jul 21, 2006.
  1. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Think about it. If the ECUs are calculating mpg using injector time
    and distance traveled, that's making a huge ASSUMPTION about fuel
    rail pressure and the actual volume of gas squirted. There's no
    direct measurement sensor for fuel pressure, to my knowledge. So
    that's one factor. Tire size and inflation pressure can also throw
    off the "miles" you see -- my own car shows about 1% less distance
    than the GPS does, for instance. Gas station pumps aren't dead
    accurate, either, even if they *are* sealed by the local dept of
    weights and measures -- they have a certain slop factor.
    All of this can add up, and depending on if the effects add or cancel
    can cause significant variation. Best to average over *many* tanks,
    and hope that cancels the effects of pump gallonage variation, and
    quit worrying about the video-game difference between 49.9 and 50.1.
    _H*
  2. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    <div class='quotetop'>QUOTE(ShellyT @ Jul 27 2006, 08:36 AM) [snapback]293152[/snapback]</div>
    I don't think there is a flowmeter involved at all. I think fuel flow is calculated based on injector % open time. Those of us who have worked on performace cars know the kind of variation you can get between injectors, in fact one of the things people do to get the more power out of their cars is to get the injectors matched. I can easily imagine a %5 variation between injectors.
  3. sl7vk
    sl7vk Member
    518
    23
    Salt Lake City
    <div class='quotetop'>QUOTE(hobbit @ Jul 27 2006, 10:50 AM) [snapback]293163[/snapback]</div>
    Well that is the point. If I had so little varience then I wouldn't have piped up. But 5 mpg is not a marginal number. I'll be filling up soon, and will keep you guys posted on what the varience is on my 3rd tank.
  4. daronspicher
    daronspicher Active Member
    1,208
    My MFD is more accurate than the non-existant mpg calculator that was in my last vehicle.
    But, I also know it misses by about 2 mpg, and is always high.
    So, I know that, and I move on... It's a Prius, not a segment of the space station.
  5. sl7vk
    sl7vk Member
    518
    23
    Salt Lake City
    Added 7.059 gallons of fuel today after riding 390 miles. 55.2 mpg while the MFD was telling me 48.7. Looks like things are evening out. I'm within 2 mpg of the mfd, and I'm just fine with that!
  6. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    The MFD is always a bit low for me. One or two mpg below my calculated. This does not include an occasional catch up tank when the outside temp is low.
  7. rylewis
    rylewis New Member
    My first post:
    I have had a 05 Prius for a little over a year now and being an "Engi-Nerd" I have been keeping track. Over 10 months I have a discrepancy of about 4.4% (the display is higher than my calculations)... not too bad.
  8. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    <div class='quotetop'>QUOTE(RyLewis @ Dec 16 2006, 07:03 PM) [snapback]363238[/snapback]</div>
    My MFD is 5% higher than my calculations. During commuting this is not a problem. On longer trips through unfamiliar country I'll knock off 5% from the mpg then divide the miles by this number to figure the gas burned.
    It is beyond me why Toyota can't accurately report the quantity of fuel remaining. It's a good thing they don't build airliners.
  9. bushface
    bushface Junior Member
    Spruce Pine NC
    My car MPG on the screen is about 6.5% to high. That stinks in such a car that is fairly advanced. But irregardless I have avreage 49.2 MPG (7187 miles with using 146.096 gallons) since new from dealer. The said thing is that I have only had the car 10 weeks and still have one more long trip planned this summer (wedding) plus my 400 mile weekly commute.
    PS is there a place that explains the abbreviations used on this website?
  10. Cacti
    Cacti Poleikleng
    193
    Massachusetts
    Here's the results of my 07 Prius
    50 tank refills calculated: 50.72 mpg
    MFD........................... 51.6 mpg
  11. sorthund
    sorthund New Member
    68
    Seattle, WA
  12. richard schumacher
    7,682
    1,064
    United States
    Did you buy most or all of that gas from one gas station? Could be their pumps are off just a tetch.
    What other car would give you 49 MPG? The sad thing here is your 400 mile weekly commute :_<
