Love my 2013 Prius Two so much I bought a Volt!
Discussion in 'Gen 3 Prius Main Forum' started by ibmoses, Oct 19, 2014.
  1. PriusToo
    PriusToo Junior Member
    84
    Charleston, S. C.
    Well said.
    Yep, when you compare any green car to any straight gasoline car , the greens ones are better,
    It's just comes down to what some fill their cars with, gas or still questionable electricity.
    You have to admit that with new emission standards , new cars are better.
    There are just too many cars on the road.
  2. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    I imagine someone with a horse & buggy once said the same thing. :) Having been to Charleston several times and living in Phoenix, I can only imagine what both would be like without cars. And having been to countries with bicycles, I can't begin to imagine how that would work in the US, even if we had significantly better mass transit. I just don't believe that a healthy planet and efficient cars are mutually exclusive goals.
  3. PriusToo
    84
    Charleston, S. C.
    Good point.
    My argument was not so much with the OP, it was with some of the other people on the thread.
    Sorry about the highjacking Bert, wish you well with your car.
  4. jkeuter
    jkeuter New Member
    Dunedin, FL
    Just curious, I don't have a Volt but a 2014 Prius, which is the best setting for the best MPG on Interstate driving?
  5. bisco
    51,961
    welcome to priuschat! eco mode. sit low and drive slow.(y)
    retired4999, Jeff N and F8L like this.
  6. ibmoses
    ibmoses Junior Member
    109
    22
    40 miles from my driveway to work. Used .2 gallon of gas. Pretty sure after I learn how to drive the car more efficiently I wont use any gasoline on my daily commute. Perhaps will use a little on very cold days but there are not many of those here.
    2013 Base Volt, only option is extra cost paint.
    MSRP $40,490.00
    Cost was $26,000.00 plus taxes/title and fees
    $7500 Federal Tax Credit
    $750.00 cash incentive from Alabama Power
    Electrical rate for my home will be reduced during "off peak hours"(9:00pm to 6:00am)
    $743.00 points on my GM Card
    I get to charge for free at work
    Roll Tide!
  7. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    So after credits it was effectively $17,000? Not bad.
    Yes, it will take some time to learn the car and how to most effectively drive it. Here in California, I went into the config screens and turned off the auto defog but maybe it's more necessary in Alabama due to humidity. Try turning it off and using "fan only" with the air directed at the windshield and see if that works okay. It will save you possibly unnecessary A/C compressor usage. I switch briefly to Eco mode to enable the compressor for defogging only when needed.
    Check your tire pressure. It's usually set low by dealers. Try to minimize braking and use the 'L' shifter position to increase regen braking To help avoid unneeded friction braking.
    How fast are you driving on your commute? I routinely get 45+ miles or better of range at a steady 55 mph and your 2013 Volt should have 3 extra miles of range due to a slightly bigger pack and slightly more efficient motor electronics.
    F8L likes this.
  8. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Was a trade-in part of the deal ?
  9. ibmoses
    109
    22
    No trade, I have a 2013 Prius Two I will be selling soon with 10,000 miles on it:)
    SageBrush likes this.
  10. ibmoses
    109
    22
    Thanks for the tips.
    I had wondered why the defrost keeps coming on when I start the car.
  11. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Just wanted to chime in as a Prius and Volt owner and congratulate the OP on his purchase.
    Honestly, I think he'll find the 80 mile round trip a little less fatiguing in the Volt.
    Anyhow, gotta run :)
    F8L likes this.
  12. PriusToo
    84
    Charleston, S. C.
    In hindsight, in my argument on here was more about Plug in cars and electric cars in general.
    One guy insulted me frequently and someone call me a troll. To be honest I'm all about hybrid cars and anything that is progressive . I'm a big Prius fan. It's too bad that I was kicked around on here because a had a different take on how plug in car and electric cars are still impacting the enviroment. They are not there Yet,but these cars are moving in the right direction. I always have thougt of Priuschat as better Forum than most, and hope to learn more from post in the future. And hopefully want run into to too many defensive folks along the way.
  13. Tony D
    Tony D Active Member
    468
    132
    Dublin, Ireland
    I'm going to skip past all the BS debate in this thread and wish you well in your new purchase, which it seems YOU bought as it suits YOUR particular needs
  14. PriusToo
    84
    Charleston, S. C.
    It's not bs, it's a worthwhile debate, you are one more person who just does not get it.
    Be open minded.
  15. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    With warm temperatures and lower speeds you should have no trouble getting 40 miles of range in your Volt.
    Unfortunately, cold temps bring about a pretty dramatic loss of range, especially if you use the heater. Some folks in freezing northern states drop down into the 20s for range. Yikes! JeffN gave you good advice so start with that.
    The Volt is very unlike the Prius in that it is quite difficult to hypermile compared to most hybrids. However, pretending like you don't have brakes is a driving technique that applies universally to nearly all vehicles. In Drive the Volt can coast for quite a ways but I have not been able to determine much of a difference between Drive and Low when it comes to maximizing range so I said screw it and drive in Low and Sport now. It's soooo much more fun to drive that way than the way I used to drive my Prii. I do miss being able to glide though. :)
  16. Tony D
    468
    132
    Dublin, Ireland
    @PriusToo - I get it, but this thread was started about someone buying a new car, and why they did it, not the environmental impact. That get discussed regularly in many other threads
    I am very open minded, hence driving a Prius, despite the stigma attached to them here in Ireland
    #56 Tony D, Oct 21, 2014
    DoubleDAZ likes this.
  17. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    Wow all this when the OP was just saying why the Volt was better for his driving situation. I was telling a friend (about the time this thread started) how if you commute was 30-40 miles each way and can charge at work a Volt is a good choice. In my case most trips are 5-6 miles each way and 1 or more times a day (no work commute) so the PiP is a perfect match. For our occasional longer trips 150+ miles the PiP is better on mpg and a bit more storage space.
    Jeff N, DoubleDAZ and F8L like this.
  18. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Very true. I miss those 50+mpg tanks on the super long trips.
    You also have to look at it from a performance/comfort standpoint as well. Some folks think about more than just pure efficiency or economics. :) The PIP and Volt are quite different in these respects.
  19. bisco
    51,961
    if i could find one for 17k, i'd buy it and stick it in the barn. that's an incredible price, congrats! might be the cheapest new volt ever purchased?
  20. SageBrush
    11,627
    2,533
    Southwest Colorado
    Truly. If a person could buy the Volt for ~ 23k (without subsidy) and GM profit, that would be a game changer
    Anyway, good for OP -- heck of a deal.
    He might even have some money left over after he sells the Prius to put up some PV. Then he would really be flying high.
    #60 SageBrush, Oct 21, 2014
