Loved my Prime, but battery range pushed me to Honda Clarity
Discussion in 'Prime Main Forum (2017-2022)' started by CyberDyneSystems, Jul 27, 2019.
  1. fotomoto
    fotomoto Senior Member
    5,638
    3,813
    So. Texas
    The OP chose a vehicle with about double the minimum EV range he needs so he should be covered even with the winter range deduction is taken into account.
    Arctic_White likes this.
  2. El Dobro
    El Dobro A Member
    7,088
    3,270
    Both my cars have resistance heaters. If you preheat while plugged in and ,while driving, adjust the heat just enough to keep the windows clear and the chill out, the consumption's not that bad.
    Arctic_White and fotomoto like this.
    51,950
    o/p needed a lap quilt in his prime
    51,950
    what i don't understand is o/p's complaint about prime a/c. my pip is still a popsicle after 7 years. is prime a/c not very good?
  5. Trollbait
    12,543
    Which is why I think PHEVs like we have today will remain a niche segment as BEVs increase share. Then the added cost of a heat pump is easier to justify when there isn't a waste heat source.
    Sounds like hot weather overwhelmed the system. Perhaps he had it set to Econ.
  6. bisco
    51,950
    ya, maybe that was it. i live in the same area, and always run eco. but prime maybe different.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    I run our Prime at 77 F and it does this effortlessly (2 bars once the cabin initially cooled down) ;).
    Could I run it cooler: absolutely
    Do I want to run it cooler: Nope
    Getting 32 miles on a charge with outside temps over 90 and a 38 mile one way commute say 77 is good enough and I’m comfortable to boot (y).
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    Same temperature setting I use, same temperatures, same range. How about that?! (y):D I keep it in eco unless it's extra hot and I have my wife with me or it's struggling to keep up.
    bisco, Prius from Dad and Raytheeagle like this.
  9. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Tint will help it from struggling ;).
    Another reason for tint(y).
  10. jerrymildred
    11,517
    14,152
    Tampa, FL
    It's already pretty dark. I suspect the original owner may have had it tinted. I'll be over at Todd's shop today to get something for my wife's '07. He has a couple Primes in stock. I'll try to remember to compare.
    Raytheeagle likes this.
  11. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    With our windshield tinted at 80% with Llumar ceramic tint, it rejects 43% of the heat:).
    Definitely noticeable when in the car and driving;).
    Next to the back hatch, that’s the largest surface and the one you’ll be near the most. Worth considering (y).
    Arctic_White and Prius from Dad like this.
  12. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    My Prime is set at 70F AUTO on Eco mode. I don't usually touch this setting. If I set mine at 77F, the heater will come on every morning. In fact, even at 70F, the heater comes on most mornings, so I always make sure to turn the climate control OFF when I get home from work. Today, I left home a few hours later than usual, and sun was up and temperature climbed above 70F quickly this morning. For the first time this summer I had to turn on the AC during my morning commute. AC load % jumped to 20s, and now seeing reduced EV range.:(
    #72 Salamander_King, Jul 30, 2019
    jerrymildred and Raytheeagle like this.
  13. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    I set the temp to 77 when the AC is required for comfort ;).
    In the morning, I have the temp set below what the outside temp is (say 68 or so and lower in the winter months). This is just to have the fan on to circulate air in the cabin:).
    EV range is affected by the ac, but worth it when it is warm to hot outside (y).
    jerrymildred and Salamander_King like this.
  14. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Some states also do not have any additional registration fees on PHEV (Nebraska is one). For every mile you drive on EV you save the fuel tax with no offsetting registration charge. This favors the Clarity, since with the longer EV range it will likely be driven more on EV, depending on daily driving habits.
  15. Blauer Glimmer
    Blauer Glimmer Active Member
    448
    169
    NY (Southern Tier)
    Similar temp ranges here, so I don't use the auto feature. During cooler morning commutes (up to about 75F), I generally open the front windows about 1/3 of the way, saving the energy-eating AC for the hot ride home.
    Salamander_King likes this.
  16. Salamander_King
    11,019
    8,954
    New England
    Same here, open windows work for most of summer, except on rainy day and highway drives. I keep my climate control on AUTO to minimize using the 11 screen, for I have it OFF most of the time. With AUTO setting, I can change the temp without turning on the large screen.
  17. ConfusedBirdie
    44
    34
    What is the real world hybrid mode MPG for a Clarity? I drive 110 miles avg a day 8 out of every 10 days and 300 miles the other 2 days. I get 59 MPG in hybrid mode. I haven’t found a more economical car than the prime for me but I’m always looking.
  18. mistermojorizin
    mistermojorizin Active Member
    310
    137
    usa
    2019 Prius Prime
    I considered the Clarity, but heard about issues with people losing power. Didn't want any part of that. Also, it has a smaller gas tank than the Prime.
    Clarity Issues | Page 26 | Inside EVS Forum
  19. farmecologist
    farmecologist Senior Member
    1,958
    1,799
    Southern MN
    Yeah..my biggest fear of non-Toyota hybrids is the lack of trust of the long term reliability of the hybrid system. Toyota's Hybrid Synergy Drive is a solid, tested platform that I trust and understand. At this point, I'm not willing to make a switch until I possibly go full BEV at some point. However, that will be a loooong time. (y)
    Thanks for all clarity and insight of other brands though! Very interesting discussion. :D
    jerrymildred, benagi, Merkey and 2 others like this.
  20. fotomoto
    5,638
    3,813
    So. Texas
    Personally as a PHEV owner and now a Clarity owner, I find this issue to be a tad overblown.
    A software service update was applied early on but I also found some of these reports were by first time owners who didn't understand how the powertrain works. They thought the car was not operating correctly because the ICE generator was running "too hard" and didn't respond to the gas pedal ( "racing" ) in high power demand situations with a depleted battery (going up a steep hill for example). The car is so dang quiet in EV mode (of course) and even in HV mode in low power situations (city or steady highway cruising) that I get it that newbies get flustered when the genset ramps up and runs faster/louder than they think it should. FWIW
    Trollbait likes this.
