Low Battery engine behaviour
Discussion in 'Prius c Technical Discussion' started by Species5618w, Aug 2, 2013.
  1. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    Sounds like another case of incompetent service department to me.
    It will probably get worse and then maybe they can "find" the cause.
  2. GregP507
    GregP507 Senior Member
    3,002
    481
    I think it's normal. The Prius was never designed to keep the battery topped up all the time, nor run the engine as little as possible.
    It was designed to stretch a gallon of fuel a lot farther than any other car in it's class, while providing good performance, interior space and reliability. It achieves all that and more.
  3. priusrick
    priusrick Member
    257
    40
    Seriously, lol, worst reply ever. Maybe read thread through first.
  4. GregP507
    3,002
    481
    It's easy to imagine all sorts of problems where none exist.
  5. priusrick
    priusrick Member
    257
    40
    When a car consistently acts one way and then all of a sudden starts acting another way, it's not some kind of magic or non-existent problem. I'm willing to wait now with my receipt to see them eat their words.
  6. Mo G
    Mo G Member
    317
    98
    Dallas,Tx
    If your battery is draining while the car is off, there is a problem. Especially if its fully charged when you pull into work, and it's almost empty, (2-3) bars, when you get in it to go home. See if you can leave the car with the service department for the day when you don't need your car. Like on your day off. I know doing that is a pain in the nice person. That way you can duplicate your problem for them. Sounds like this should be fixed as soon as possible.
    ThilinaK likes this.
  7. GregP507
    3,002
    481
    That might be a problem if that picto-gram were an accurate measurement of battery capacity. I'm not so sure it's intended to do much more than give us an assurance that the system knows what it's doing. Voltages are not good indicators of true battery capacity, (and I'm not sure it's a straight read-out of voltage) because it can fluctuate due to temperatures and chemical reactions which can occur after the battery is idle for awhile.
  8. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    I've never seen my battery bar fluctuate from full to empty just from sitting off before, though. I have seen it drop or raise 1 bar, but never more than that.
    Mo G likes this.
  9. Mo G
    Mo G Member
    317
    98
    Dallas,Tx
    Has your MPG taken a drastic hit as a result of the fluctuations in the battery?
  10. priusrick
    priusrick Member
    257
    40
    I have not noticed a decrease in my MPG but I'm sure there is some minimal decrease. It only occurs when the car is out in direct sunshine.
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    In a g2 Prius this can be caused by a bad 12 volt battery.
    Its low and it puts a big load on the inverter and guess
    Where the inverter finds power? This happens very fast.
    Has the car ever needed a 12 volt jumpstart?
  12. priusrick
    priusrick Member
    257
    40
    never had to jump it. It happens occasionally, but it is not clear why it happens when it happens. I thought it was heat, but it happened on a nice day as well.
  13. James Luckett
    James Luckett Junior Member
    posted in error. sorry.
    #33 James Luckett, Feb 27, 2015
  14. You could try posting in the regular Prius (not Prius c) forum maybe someone there has a Prius with a similar issue.
  15. bisco
    52,854
    well, this thread is two months old, but just for funnies, i'll jump in.(y)
  16. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Under those conditions you can forcecharge the HV battery if you like. You can conceivably charge it all the way, if you have time in traffic. For safety use both braking systems. It may sound wierd and dangerous, but it is not. Keep car in drive, keep foot on brake. Use handbrake also.l
  17. Andyprius1
    2,327
    859
    Cool CA
    Step on accelerator.
  18. Andyprius1
    2,327
    859
    Cool CA
    Should anybody have any doubts about this procedure, try it in a empty parking lot.
  19. Mo G
    Mo G Member
    317
    98
    Dallas,Tx
    Update?
  20. priusrick
    priusrick Member
    257
    40
    I have not experienced serious issues in a while, no idea. Maybe it doesn't happen during the winter, find out soon. It's already getting toasty in Dallas.
