Low battery error codes; water in wheel well.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by John McG., Apr 28, 2018.
  1. John McG.
    John McG. Junior Member
    55
    25
    So I was getting dashboard symbols popping up. The triangle, brakes, VSC, check engine. The ODB reader shows a C2318 code. Seems this happens if there is a ground or resistance issue in the transmission IGCT relay or fuse, OR like many other weird problem, a low voltage situation with the auxiliary/starter battery. So I charged the battery using the front fuse panel contacts and the voltage is 12V or above. So I took the battery out and discovered the battery sitting in 2 inches of water! It is a 5 year old optima yellow top so it may be bad, but was wondering if anyone had any experience with batteries in water, or a similar issue with water in the wheel well. I have the battery on a good charger to see if it can pass a load test. What a weird one. Any thoughts?
    Well, a little more info. I cleaned up the water, the battery took a full charge quickly. I brought it to NAPA and they load tested it and it was fine. I cleaned the contacts as suggested in error report. If I turn off the car and restart the codes come right back. Only thing showing is the C2318 codes.
    #1 John McG., Apr 28, 2018
  2. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    EyePrime and Raytheeagle like this.
  3. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Definitely address the water issue! Doesn't play well with electricity!
  4. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
  5. EyePrime
    268
    115
    2018 Prius Prime
  6. bisco
    52,883
    the bottom and sides of the battery are waterproof. keep an eye on the charge, it may need to be replaced.
    check the threads for selling the car from water infiltration.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    C2318 is low 12 volt supply.
    You have a bad hatch leak cracked weld seam at upper passenger side hatch valley.
    There’s a rubber plug in the battery well. Remove it and leave it out. Take spare tire out probably water under there too. Really common. Hundreds of posts about that.
    In fact the post right below yours is a years old thread on hatch leaks.
    Replace your optima. Based on how many times people say they had there 12 volt battery “load” tested and they say ok and then soon after it goes dead again I have no faith in anyone’s load test.
    Check it yourself. Measure the 12 at the front jump points with car off. Then with car off turn on the headlights in Highbeam and leave them on for 5 minutes. With car off. A good optima should not show any lower voltage.
    My optima when tested was 12.6 car off before test and stayed at 12.6 for 5 mins in high beam.
    John McG. likes this.
  8. John McG.
    55
    25
    Again more info, I brought the Prius to Toyota. They are telling me after analysis that it needs a new hybrid battery. Surprised. There is NO code fo P0A80 or something on the high voltage side. The only code is on the 12V side for C2318. Any help out there? Seems like an expensive adventure if the hybrid battery isn't the problem.
  9. John McG.
    55
    25
    Thanks, I trust the load tester, but no harm in doing this test as well. Voltage at the front after the car sits for 12 hours was 12.5V.
    Any idea where the IGCT Relay is located? Interestingly I can start the car and clear all codes. IT will drive for ever running correctly (no fan noise, etc.) until I stop and try to restart. Then it throws the trouble lights and C2318 code.
  10. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Did you pay for the dealer analysis? if so there should be some paperwork that came with the receipt.
    Please post all of the codes that the dealer supplied.
    How many miles on the vehicle, and is this the original HV battery?
    Raytheeagle likes this.
  11. John McG.
    55
    25
    The codes were pulled using an Autel ODB reader as a well as a high end SnapOn scanner. The dealer tech "says" he pulled a series of codes all pointing at a new HV battery and rattled off a list ( no print out). My trusted mechanic and I don't get those main codes which leads me to being suspicious. Was he not able to identify the problem and made one up to get the car off the lift? He conveniently did not enter any notes in the account record either so I want to verify his work. The Prius has 82,000 miles on it. They also did not charge me ( even though they said they would). A nice gesture but you also have to wonder, they can't be held responsible for anything if they don't charge me. I want to get the diag protocol for the C2318 code and see if I can get a copy of Techstream working before I load in a refurbed HV battery. My hunch is its a harness wiring issue.
  12. John McG.
    55
    25
    There a few members who have mentioned receiving a C2318 code, but never close out their threads with a resolution. Please post your final resolutions, its really valuable to the forum.
  13. John McG.
    55
    25
    Ed, I check this first thing thanks to Mikes video. Its completely sealed, even the paint isn't cracked. Beats me how that water got in there. Nothing in the real of the car is wet and no mildew at all. Puzzling. Battey hlods voltage well, snaps back to 12.2V
  14. edthefox5
    10,096
    4,840
    Clearwater, Florida
    where are you measuring it?
    If the hatch is not cracked where the roof meets the quarter panel you may be missing the spoiler under the battery under the car. There’s a little plastic panel under both rear wheels. It looks like mud shield behind the rear wheel. If one falls off it tends to allow water into that battery well area.
    What does the 12 volt battery voltage look like after the high beams have been on for 5 minutes.
    Not after you turn the lights off while the high beams are still on.
    Not what it snaps back too.
    #14 edthefox5, May 2, 2018
  15. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Did you take a look at the wiring by the HV battery fan. If those are corroded, this could help you determine that the leak location is above that area.
    edthefox5 likes this.
  16. John McG.
    55
    25
    Drops to about 11.5 V measured by the display diagnostics. I need to get TechStream software up and running on my laptop. I should have the cable tomorrow. This will let me check the voltage at the transmission controller where it is sensored. Also if there is any evidence the HV battery needs replacing.
    I learned something new I could not figure out. The C2318 code says to check the function of the IGCT Relay. Where is this relay located? This is marked as "P-CON" in the primary fuse box under the hood.
  17. John McG.
    55
    25
    Really good idea. The fan is working ok. Absolutely no water corrosion or staining anywhere so this looks like a brand new problem. Wondering if someone drove through a DEEP puddle and won't fess up. Family diagnostics maybe required. :)
  18. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    Family diagnostics! Amazing what you can find out that way.
  19. edthefox5
    10,096
    4,840
    Clearwater, Florida
    11.5 volts is the battery is done. Buy a new battery. It will not hold a charge.
    In a Prius any 12 volt issues just replace the battery. This site has probably 5000,000 posts about the mystery of this 12 volt.battery.
    Its been the #1 post on this site soon to be replaced with the mystery's of the Hybrid Battery.
  20. edthefox5
    10,096
    4,840
    Clearwater, Florida
    What does this mean?
    You want to measure the 12 volts at the front jump points with a DVM.
