Low-beam headlight bulb suggestions?
Discussion in 'Gen 3 Prius Main Forum' started by 134HP Bard Womyn Magnet, Jun 12, 2023.
  1. 134HP Bard Womyn Magnet
    103
    28
    NYC
    I've toured the threads and wanted to ask in 2023: suggestions and links for bulb replacement? My 2014's low-beam is out and I see conflicting info on LED, HID, etc. I'd prefer something I can pop right in (wearing gloves) without a lot of conversion/tweaking.
    Previous owner seemed to have original bulbs in for the lo-beams and we might as well have not had any headlights at all...OK, slight hyperbole there but the point is an improvement in that area would be welcome. The illumination absolutely sucked, just a little glow barely in front of us on the road and that's about it, and that's even with the driving lights on too (which look to have been converted to LEDs). High beams are great though!
    Thank you for any suggestions (and please post links if so inclined).
    #1 134HP Bard Womyn Magnet, Jun 12, 2023
  2. ColoradoBoo
    ColoradoBoo Senior Member
    1,358
    987
    Monument, Colorado USA
    I've always liked the Silvania Ultra Halogens (I think they are in an orange container) And you want to always change bulbs in pairs...if the right side goes out, change both right/left side. (They are the same age so won't be long, anyway, before the other goes out.) And you want the lights to shine the same, older bulbs get dimmer as they age.
  3. Tombukt2
    Tombukt2 Senior Member
    13,879
    2,521
    Durham NC
    Aux Beam S1 series hi n lo I think h8 and h11 are on gen3. Cut off for the low beam is perfect as it's built into the housing and the high beam is wide open on the generations 3 with one projector The s ones on high beam will blind people and the low beam is exceptionally bright but the cut off is razor sharp You can see it right across the headrest of the back seats of the car in front of you.
  4. ChapmanF
    19,065
    Some early Gen 3s came with a problem of overvolting the halogen headlights, which made their lifetimes extra short.
    If your car is the 2014 in your profile, probably that's already fixed.
    For someone with an earlier Gen 3, it can be good to stick with the 'standard' halogens (the ones usually hanging on pegs down by your ankles, where the shops hope you won't see them), instead of the extra-bright ones that are usually hanging at eye level in the flashy packaging. The extra-bright ones are built with a trade of longevity for brightness to begin with, and then if somebody puts them in one of the older Gen 3s where even the standard bulbs burn out fairly soon, the extra-bright ones will drop like flies.
    Again, I think the cars with that issue were early Gen 3, 2010 or 2011 and not all of those, so it shouldn't be an issue in a 2014.
  5. rjparker
    rjparker Tu Humilde Sirviente
    11,152
    6,989
    Texas Hill Country
    Be sure the retrofit bulb is designed for H11 sockets. Otherwise it won't fit and the connector will be different.
    Just last week I went from an Auxbeam Led low beam priced around $35 a pair to the Lasfit H11 Led for $55 a pair. While both were brighter than the standard halogens, the Lasfit was better and has a wider beam allowing you to see the side of the road much better.
    It is important that the plastic headlight assembly has a clear lens. If it is fogged use one of the diy kits or have it done by someone.
    Finally, some cheap Led bulbs will not work in halogen projector headlight assemblies without blinding oncoming traffic.
    No matter what brand, a retrofit won't be as good as a factory led headlight assembly.
    Amazon.com: LASFIT H11 LED Bulbs, 2023 Upgrade H8 H9 H16 LED Light Bulbs 6000LM Super Bright Conversion Kit Plug and Play, Non-polarity-2 bulbs : Automotive
  6. 134HP Bard Womyn Magnet
    103
    28
    NYC
  7. 134HP Bard Womyn Magnet
    103
    28
    NYC
    Thanks for that link. Regarding the above, you mean if it's fogged on the exterior? Any DIY kits you recommend? I saw the Wipe New but wondered if it sounded (and was priced) too good to be true. Feel like you'd have to buff/sand and maybe coat?
    May I rely on your expertise and ask you to look at this photo? This is how the working side looks. I'd say similar or less on other side. Can I get away with those LEDs or do you think this will require repair/halogen use?
  8. rjparker
    11,152
    6,989
    Texas Hill Country
    They probably need cleaning if the yellow is there. This is my 11 year old headlight that has been cleaned three times over the years.
    This is the kit I like. No power tools needed but it requires some elbow grease and careful following of the instructions.
    Amazon.com: SYLVANIA - Headlight Restoration Kit - 3 Easy Steps to Restore Sun Damaged Headlights With Exclusive UV Block Clear Coat, Light Output and Beam Pattern Restored, Long Lasting Protection : Automotive
    It has a final uv coat as well.
    #8 rjparker, Jun 12, 2023
  9. 134HP Bard Womyn Magnet
    103
    28
    NYC
  10. rjparker
    11,152
    6,989
    Texas Hill Country
    Watch this video. Note you use surface activator twice per headlight. I would wait on the final uv coat until both headlights are ready. As in the video, the plastic still looks hazy until the uv coat. I would write down and follow the steps from the video. The supplied instructions are not as clear.
    It is probably possible to do two cars with one kit. As an alternative, Walmart Automotive does it for a reasonable price.
  11. 134HP Bard Womyn Magnet
    103
    28
    NYC
    I actually watched this already and was too taken with the acting to absorb any of it.
    But seriously, thanks, looks pretty simple and appreciate the tip to wait on the final coats.
    I ordered some of the Lasfit H11s tonight and will see how they perform first...I'm rarely driving at night lately so if it's a mess I'll have some time to order the restoration kit and clean up the plastic.
  12. KevininFl
    KevininFl Junior Member
    62
    16
    Fort Myers Fl.
    I would go with the 30000LM set from Hikari, you can get a set for your High Beams also.
    They are cheap and good,you can find videos of them on YouTube if you want to see the difference.
    https://hikariled.com/
  13. 134HP Bard Womyn Magnet
    103
    28
    NYC
    Oops I already went with @rjparker 's recommendation, but thank you. I haven't put them in yet, partially because my socket set is at work, partly because my car is now doing a rough start last few days and I'm wondering if I should drive it straight to CarMax before the HG blows! (Hope not, but who knows.)
