Low beam headlight issues
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bert66, Mar 24, 2017.
  1. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    I find the beam shoots nicely since the prius has a projector/reflector. These bulbs in the ridgeline are a bit off since the bulbs sits @the 1 o'clock position, beam has little hot spots(blame the reflector design). Throw is not as long but no more replacing bulbs and I can see just fine. The 4th gen prius led headlights are blinding bright, no sure how it is legal???
  2. walter Lee
    1,126
    376
    Maryland
    I've replaced my low beam headlights several times.(both sides, H11 ) This year I received a recall from Toyota about the low beam headlights bulbs burning out prematurely and that the dealer fix is a different wire harness
    Walter Lee
    2010 Toyota Prius III
    Blue exterior
    odometer = +90,000 miles
  3. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Some cars were shipped with a wire harness where the wire gauge was too small. This causes a voltage drop. If you operate halogen bulbs at too low a voltage they won't "self repair" and burn out prematurely. This doesn't apply to DRL use where some vehicle DRLs use the halogen headlamps in series. In this case they emit light but don't run hot enough to evaporate the tungsten on the filaments.
    There is a TSB out for the Prius GIII about this. As noted above, the fix is to replace the wire harness bits (just the last bit leading to the bulbs I think).
  4. ChapmanF
    18,970
    That's correct about the existence of the TSB, but exactly backwards about the nature of the issue. The defective wire harness is too heavy in gauge, delivering a voltage to the bulb that is too high. The lifespan of any incandescent is reduced severely by overvoltage (life is inverse to roughly the thirteenth power of applied voltage).
    The fix in the TSB is to add a substantial length of wire leading to each bulb, shaving off an additional ½ volt, roughly, at the bulb, giving a more reasonable life. More details on the fix are here.
    -Chap
    CR94 and xliderider like this.
  5. mtnbkr
    mtnbkr Junior Member
    27
    MD
    You got it fixed via recall???
  6. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    I'm probably going to skip having the recall done on our 2011. I would have to remove the HID lights and ballasts I've installed on the vehicle. ;)
    Haven't had any problems with the HID bulbs and ballasts from the high voltage Prius electrical system.
  7. Fearless Flyer
    Fearless Flyer Junior Member
    Syracuse, NY
    We just got a "Customer Support Program Notification" in the mail yesterday(1/7/18) regarding halogen headlamp time being shorter than expected.
    Toyota is offering to replace BOTH Low beam harnesses and bulbs(both sides) if you have a low beam that goes out, good through 10/31/2019. In addition, they will reimburse any costs incurred if you replaced a bulb yourself prior to receiving this communication.
    I got the notice yesterday and my driver-side low beam went out the very same evening(what are the chances of that?). In addition, we had the same issue on the right side this past November(2017).
    Promptly called my local dealer and brought it right in only to find they don't have new bulb/harness required and gave me a free loaner vehicle it parts come in since it's a safety/liability issue.
    So, 2010-2011 Prii owners, watch for this mail from Toyota!!
  8. Bham_prius
    Bham_prius Junior Member
    35
    bellingham
    Cool any builiten number associated with this? I am actually replacing my lights today...
  9. Bham_prius
    35
    bellingham
    LOL checked the mail.. I got the letter as well
