Low Beam LED
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Costy, Nov 13, 2014.
  1. Costy
    Costy Junior Member
  2. dle
    dle Junior Member
    65
    SoCal
    I just ordered a similar set but at 50w. It should all be plug n play, just make sure you ask for the H11 kit when you order it.
  3. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    So far no one has really found these PnP LED lights acceptable for replacements as lowbeam lighting. It may be bright enough, but the dispersion may not be so good because the LED panels are far from being a point light source like the halogen and an HID arc.
    SCH-I535
  4. pauerbach
    pauerbach Member
    101
    34
    I'd have to agree with xliderider. Aftermarket kits like these rarely provide adequate beam shaping - that is to say the light is scattered out in all directions and not projected down on to the road correctly like the factory headlights. Apparently the xenon supply HID kit has worked well for other members. I can't vouch for it personally, but it's probably a better bet than these.
  5. xliderider
    8,140
    3,277
    Honolulu, HI
    A low cost light upgrade is the H11 to H9 bulb conversion where you easily modify a low cost 65w H9 halogen bulb so it can be mounted in the standard H11 projector.
    The H9 bulb provides about 50% more light with a little extra heat that so far has not caused any problems to myself and several other members who have done it. The H9 bulb burns very bright and white, it is a very worthwhile upgrade. Just buy quality name brand bulbs like Philips or Osram, don't buy any Chinese stuff. Even the name brand bulbs cost under $20 per pair, much less than so called premium H11 bulbs. See link in my signature below.
    SCH-I535
  6. Costy
    Costy Junior Member
    dle, maybe you will attach some photos of your led kit and let us know how it goes. If it's a plug n' play job,
    if the output light is stronger than halogens, if the light is spread out correctly...stuff like that.
    I am on H9 bulbs for more than 12 months now but I'm still not happy with the light.
    I was looking for something else but not so powerful like xenon ...
  7. dle
    dle Junior Member
    65
    SoCal
    Sure, I'll post them up when they arrive. ;)
  8. Sbceezie
    Sbceezie Junior Member
  9. xliderider
    8,140
    3,277
    Honolulu, HI
    $180 if you use code NOV10 at checkout for a 10% discount. ;)
    You can get a really nice HID kit with that much money though.
    SCH-I535
    Sbceezie likes this.
  10. jcherpack
    jcherpack Junior Member
    Pennsylvania
    I'm looking for some advice...my low beams are not bright enough; never have been. What are the caveats of buying aftermarket lights? Is there a basic choice to get better nighttime visibility with minimal risk? My high beams are fine; no complaints there. Thank you for your input.
  11. xliderider
    8,140
    3,277
    Honolulu, HI
    I highly recommend the H11 (stock) to H9 bulb conversion for your lowbeams. Simple modification of the H9 bulb to fit in your lowbeam projector housing. Get 50% more light, no extra wiring or ballasts to mount.
    Link in my signature below.
    SCH-I535
  12. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    Or, you can get a Morimoto kit from The Retrofit Source for $150
  13. Sbceezie
    Trentodestiny, are these the ones you're talking about? Would these work as a low beam replacement or supplement?
    Morimoto XB LED Fog lights
  14. trentofdestiny
    1,104
    227
    Harrisburg, PA
    No, I was referring to a Morimoto 3Five HID kit, H11 size for the Gen III. Other Morimoto kits with other size bulbs are normally the same price
  15. John Molani
    John Molani New Member
    Austin, TX
    Did the Morimoto Kit and it's a mess of wires etc to hide within the engine bay etc. Not to mention the cost etc to value
  16. trentofdestiny
    1,104
    227
    Harrisburg, PA
    Yeah. I didn't use their relay harness even though it came with it for free.
    iPhone ?
  17. StarCaller
    StarCaller Senior Member
    1,280
    732
    Cedar Crest, NM, USA
    I guess you would have been better off with this one here: (y) :D
  18. liskipper
    liskipper Member
    374
    79
    Long Island, NY
    I have rarely had good luck with anything shipped from China. Support is awful as is the quality. If you return it the shipping will generally cost more than the item is worth.
  19. trentofdestiny
    1,104
    227
    Harrisburg, PA
    I define value with the morimoto kit as follows: over 2 years before I needed replacement bulbs, and discounted to $25 from $40 by TRS. After 3 years, I needed a bulb but discovered I had been using H11A even though they were supposed to send me H11B. Bulbs were replaced free. After 4 years needed new ballasts, one was free and I bought another one for $35 to match. So how many of those cheap kits would I have had to buy to cover 4 years (or more)? Not counting the hassle of swapping out components.
    iPhone ?
  20. StarCaller
    1,280
    732
    my post was meant ironically.
    I have in three cars morimoto hid kits from the retrofit source & I honestly couldn't be more happy with their quality & especially their customer service!
    BION
    StarCaller
    trentofdestiny likes this.
