Low beams stopped working but my high beams work
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by John Krauchunas, Aug 7, 2025.
  1. John Krauchunas
    John Krauchunas Junior Member
    Chicago
    I have a 2008 prius, my low beam headlights stopped working, but my both high beams still work. They use the same bulb.i checked all the fuses in the engine compartment. And changed out every relay that clicked when I either turned on the headlights or switched from high to low. Can someone give me ideas and where to go from here.
  2. Tideland Prius
    16,675
    Have you changed the bulbs? The low and high beams use different filaments so it’s entirely possible to blow the low beams while the high beams still work. Take the bulb out and have a close look.
