Low beams too dim
Discussion in 'Gen 3 Prius Technical Discussion' started by Maddie D., Nov 24, 2017.
  1. Maddie D.
    Maddie D. New Member
    Nc
    I really need help . I am parking my 2014 Prius trim 5 until a solution is found for my low beams .
    I literally have at least wrecked 5 times in 2 weeks because I cannot see. The other scary thing is I entered Interstate 85 the wrong way because I couldn't see. So yes my car is parked.
    Other people that ride with me at night they can't see either. So it's not just me. I have taken my car twice to two different Toyota dealerships. They say that my lights are adjusted fine. I am not a Prius mechanic but I can assure you those lights are not right.
    I'm not a new Prius owner but this is the nicest one I've ever had. I saved for several years to pay for it in cash so wouldn't have a car payment. And so far I have been terrified. Other people have been terrified. I cannot imagine what that car of people felt like when they were coming head-on at me when I was on the wrong side of the interstate. Thankfully there was enough room for me to jerk my car over without hitting the wall.I have never done anything like that in my entire life. If anybody can help me figure out how to make my low beams brighter and More in front of the car I would greatly appreciate it. I have watched a ton of YouTube videos where it shows to put the screwdriver in the little hole and turn the gear. Yes I've done that. A lot. Or what I would consider a lot. Thank you for your help.
    beardlesswhelp likes this.
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    If it's a level five then it's got factory LEDs for lowbeams and they're plenty bright. I've driven the late model Corollas with factory LED lowbeams and they're fine.
    If the dealer has checked the aim and certified that everything is working, then perhaps you should get your eyes examined by an optometrist/ophthalmologist.
    Paranormal Rob and bisco like this.
  3. Danny3xd
    Danny3xd Active Member
    238
    149
    CT. U.S.
    Howdy Maddie.
    This must be terifing! I will post pics but those polishing kits are amazing and work great.
    But please do forgive me, but could there in fact be a vision problem As X is asking?
    Seemed like over night but way back when I turned 40, eyesight just went. More importantly, might be something more pressing then just natural progression.
    Worth a thunk, me thinks.
    Please post how your doing with this! We ugly but caring folk. LoL
  4. xliderider
    8,140
    3,280
    Honolulu, HI
    If you are an older driver, you may be having a hard time with night vision. The LED lowbeam lights do put out a cooler color temp (on the bluish side) beam that may be harder to detect contrast when compared to the warmer old school halogen bulbs that put out light that is on the yellowish side of the color spectrum.
    Your five also has foglights. Perhaps installing yellow bulbs in the foglights will help with your night vision?
    This is my daily driver, and as you can see the yellow foglights contrast nicely with the wet pavement in front of the vehicle. These yellow bulbs are 2500K color temp. Your factory LEDs are probably in the 5000 to 6000K temp range.
    padroo and Danny3xd like this.
  5. fuzzy1
    10,699
    Can you point the car at a close wall and get a picture of the light pattern to show to us?
    If your low beams are turned on and functioning -- as opposed to just having the LED DRLs turned on -- then there should be absolutely no problem with brightness. These should actually be brighter than your previous incandescent headlamps, and have a better pattern than any of your 20th Century cars.
    A wall pattern photo will help us see if the aim is seriously messed up, or if you are mistakenly using the DRLs instead.
    #5 fuzzy1, Nov 25, 2017
  6. xliderider
    8,140
    3,280
    Honolulu, HI
    Yeah, it sounds like the OP is driving around with the light switch in the DRL position.
    fuzzy1 likes this.
  7. bisco
    52,820
    take it to an aftermarket shoppe (in the daytime!:eek:) and discuss the issue with them, so they can offer you the best solution.
    perhaps an indy mechanic can test it at night for you, to determine if it is the car, or your vision.
    all the best, and please stay off of 95s this january.:p
  8. Vman455
    Vman455 Senior Member
    540
    556
    The Middle
    So, to recap here:
    -5 accidents in 2 weeks because you "cannot see"
    -entered I-85 exit ramp and almost hit someone head-on
    -lights have been checked by 2 different dealerships, who both said there's no problem with them
    Read very carefully (I'll use large print so you can see it): STAY OFF THE ROAD. TAKE AN UBER, TAXI OR BUS TO AN OPHTHALMOLOGIST. You may have an eye condition that is not only injurious to your health, but putting other drivers at substantial risk.
    Threej likes this.
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    I believe you that you've been trying to drive with inadequate lights because your passengers observe the same thing. So, unless your passengers also have vision problems, it's not your eyes.
    I'm with @fuzzy1 on this. My first guess is that you're driving with the daytime running lights (DRLs) rather than headlights. A picture would help. If that's not it, take it to the Toyota shop after dark (shouldn't be hard to do this time of year) and ask the service manager or someone to take you for a ride and show you how the lights are OK.
    Danny3xd and fuzzy1 like this.
  10. Tande
    Tande Active Member
    553
    339
    Mich.
    If "Maddie" is in fact driving with only DRL's......does that also mean NO taillights??
  11. xliderider
    8,140
    3,280
    Honolulu, HI
    Not sure, if the stalk light switch is in the Parking lights position, then DRLs might still be on and running lights all on, including rear running lights.
    CR94 and fuzzy1 like this.
  12. fuzzy1
    10,699
    So, is this yet another 'one and done' member?
    She did come back late enough to read the first 5 replies, before vanishing. My top suspicion is operator error with DRLs, but there are other possibilities.
    #12 fuzzy1, Nov 27, 2017
  13. xliderider
    8,140
    3,280
    Honolulu, HI
    Yeah, probably operator error and too embarrassed to post a reply.
  14. jerrymildred
    11,517
    14,167
    Tampa, FL
    That's too bad. I've sure made some way dumber mistakes than that and you haven't run me off yet. :whistle:
  15. xliderider
    8,140
    3,280
    Honolulu, HI
    jerrymildred likes this.
  16. jerrymildred
    11,517
    14,167
    Tampa, FL
    I meant, "Y'all." :ROFLMAO:
    Edit to add: Or should I say, "All y'all?"
    Danny3xd, m.wynn and xliderider like this.
  17. Paranormal Rob
    Paranormal Rob Active Member
    244
    107
    RDU NC
    2013 Prius v wagon
    I have a 2013 v5 and mine work great and look just like that.
  18. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
    Y'all is a small group...maybe 3-4. All y'all is a bigger group, but also had more emphasis.
    "Y'all coming to dinner?"
    "All y'all coming to dinner?"
    m.wynn, xliderider and jerrymildred like this.
  19. bisco
    52,820
    i hope she didn't enter the interstate the wrong way again.:eek:
    m.wynn, Danny3xd and jerrymildred like this.
  20. jerrymildred
    11,517
    14,167
    Tampa, FL
    A scary thought!! Also a very popular way to die in and around Tampa.
    m.wynn and bisco like this.
