Low cell block voltage
Discussion in 'Gen 2 Prius Main Forum' started by Johnhersh, Apr 15, 2019.
  1. Johnhersh
    Johnhersh Junior Member
    Gosport Indiana
    I just bought a Prius with some electrical problems. I hooked up TechStream and got a few different codes. P0A80 p3000 and poaa4 and poaa1.When I checked the cell voltage through TechStream it showed all blocks were around 15.9 volts except block 4 was around 7 volts. I was wondering if anyone on here has experienced similar symptoms or if anyone would have any advice. Doesn’t 7 volts seem really low for a block?Also the Prius won’t go in ready mode.
    52,862
    yes, probably why you're getting the P0A80
  3. 09Prius2
    09Prius2 Member
    201
    88
    FL
    You obviously have a bad cell unless its just a bad connection / corrosion. Of course thats a big difference so it could fry the whole battery quickly if it were operated like that.
  4. Johnhersh
    Gosport Indiana
    So could it possibly be just a bad connection or corrosion?
  5. bisco
    52,862
    maybe. you'd have to open the case and look. how is the 12v health?
  6. Johnhersh
    Gosport Indiana
    I figured it out.Opened up the case and one of the modules on block 4 was completely blown.I could actually lift the top up on the cell.Changed it out and everything works fine.However I still have a red triangle. I checked everything with Techstream and there are no codes.Will it sometimes take a bit for the red triangle to go out or is there still a problem?
  7. bisco
    52,862
    tech stream should have a way to clear the codes, was the new module within parameters?
    can you make the car ready?
  8. Johnhersh
    Gosport Indiana
    Yes the Prius goes into ready mode and runs and drives fine.I have cleared all the codes and there are no more codes showing. But the red triangle is still on
  9. bisco
    52,862
    doesn't ring a bell. idk the connection between the codes and lights. a cpu i assume? give it a few days and if it doesn't go out, try a new thread stating the problem
