low coolant, no leaks
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by thomassster, Mar 3, 2022.
  1. douglasjre
    douglasjre Senior Member
    2,249
    751
    Null, NL
    How would you tell the difference between antifreeze and the water created from the catalytic converter
  2. hill
    9,023
    Similarly if the head is warped - the leak comes by way of steam bypassing head gasket) that funnels through the exhaust system. Just read that recently.
  3. dacoobob
    dacoobob Member
    83
    46
    Kansas City, MO
    Four Touring
    Toyota coolant is bright pink. When it leaks into the exhaust the liquid evaporates and leaves behind pink crystal residue and stains.
  4. BiomedO1
    BiomedO1 Senior Member
    4,554
    2,394
    Left Coast
    That would be a long way to go with a borescope, since the heat exchanger is located between the drivers and passenger seat in that center hump. Next time your under the car, it's right behind the CAT - you'll see the inlet and outlet coolant hoses. :D
  5. dacoobob
    dacoobob Member
    83
    46
    Kansas City, MO
    Four Touring
    that's how my mechanic diagnosed my leaky heat exchanger. not sure if he used an extra-long borescope probe, or just disconnected the cat to take a look. either way the leak was obvious visually.
  6. BiomedO1
    4,554
    2,394
    Left Coast
    I'm sorry, but your mechanic may be "pulling your leg". I don't know how anyone can push a scope through your CAT or your muffler to "eyeball" the heat exchanger.:(:cry:
    It can be done, but would require some cutting and welding; which would be free and on his "dime"; if the customer declines the repair. I know I would be pretty P.O.ed if someone cut my exhaust system in half and said pay me 2K or get it out of here.
    #26 BiomedO1, Mar 24, 2022
  7. Michael Wood
    Michael Wood Active Member
    181
    118
    Boston, MA
    2020 Prius Prime
    How is the coolant level behaving since the dealer repair? Some 2020 Primes have the same problem. Very common.
  8. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    I was monitoring for about a month and no really major difference. I haven’t been monitoring it after. It’s tough to say whether the repair made any difference but for me,but it was good piece of mind and glad Toyota decided to cover it for me.
