Low estimated EV only mileage
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by retired4999, Feb 26, 2014.
  1. retired4999
    2,652
    627
    Eau Claire, Wi.
    I have my garage at 45 degrees, the wife does projects in the other side and thats the lowest my stat goes!;)
    Today -18 below when I went to coffee came home 2 hours later about -12 below, 5.5 miles round trip all EV.:D
    52,695
    cheeseheads.:rolleyes:
    retired4999 likes this.
  3. retired4999
    2,652
    627
    Eau Claire, Wi.
    Thats all I have up there, Cheese! :)
  4. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Must have nuts also, because you have to be nuts to drive home from coffee with no heat!
  5. markabele
    5,084
    1,782
    Nebraska
    It's 2.75 miles. It would be stupid to turn on the heat. He is in the car probably 7 minutes max, probably more like 5 or 6.
  6. retired4999
    2,652
    627
    Eau Claire, Wi.
    You don't get much heat in 2.7 miles at -12 below anyway. You just get heat and your home turning it off.
  7. retired4999
    2,652
    627
    Eau Claire, Wi.
    You are correct! 5 to 6 minutes. Don't even needs gloves for such a short trip. :D Would not like to go very much farther however! :p
  8. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)Low 60 degree temperatures today. Had no problem making my 10 mile work commute. Arrived home with 1.4 EV left. Hurry up spring and summer.
  9. markabele
    5,084
    1,782
    Nebraska
    What do you do that you had to go in on a Sunday?
  10. El Dobro
    El Dobro A Member
    7,102
    3,282
    I've been using the seat heater on my EV runs.
  11. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    -12 I pre heat screw the milage, and where I live 2.75 would take about 12 plenty of time for heat to come up!
  12. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)Property maintenance issue, resolved.
