Low Fuel Question
Discussion in 'Gen 2 Prius Fuel Economy' started by donzoh1, Aug 23, 2020.
  1. donzoh1
    donzoh1 Active Member
    434
    149
    Lenexa, KS
    My 2007 gets 40 to 45 mpg in mixed driving. I usually fuel at 1 dot left on the gauge but I've never put more than 9 gallons in. Usually, this is around 350 miles. What warnings should i expect below this fuel level and how far will this car likely go after the ICE quits?
    kenoarto likes this.
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    There is a blinking last dot, ideally you never see it.
    If you drive at all after you run out of gas, expect to have to tow your car to the dealer and wait for a high voltage charger from Toyota Regional. (2 weeks?)
    I ran my Gen 2 out of gas twice: it takes 3 gallons of gas before it it will restart, if you try to start before you have 3 gallons in it, it takes another 3 gallons. If you try more than 3 times, you need the tow truck. It will be very sluggish for about 5 miles after you run out of gas. If you run out of gas, 35 MPH will be your top speed.
    Nothing good can come of running out of gas. Consider refilling at 2 dots instead of 1.
    48,979
    there is also a very quiet beep. if you're hard of hearing, you won't hear it. if the ice quits, it depends on the level of the battery charge, but not far, and it is not good, especially for an older battery.
    also, you have a fuel bladder, which can lie to your gauge.
    there is a safety amount of gas when the last bar is blinking, maybe 2 gallons? it is in the o/m.
  4. dolj
    dolj Senior Member
    7,506
    3,772
    Wellington, New Zealand
  5. lpf
    lpf Member
    113
    33
    Greece
    Expect 30miles remaining (I calculated your data) with 1 dot (not blinking).
  6. bisco
    48,979
    do the euro models behave similarly to n/a? no bladder, correct?
  7. bisco
    48,979
    not following you
  8. lpf
    lpf Member
    113
    33
    Greece
    I don't know about bladder. When I'm at the last dot, 5-7 liters remain at the tank. This calculated with 5,3 l/100 mean 100-120 km to go. But I will fill gas at that point.
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,782
    2017 Prius c
    THIS.
    The gas gauge is designed to help prevent you from being stupid.
    Go with the flow. Don't BE stupid.
    srellim234 and lpf like this.
  10. donzoh1
    434
    149
    Lenexa, KS
    When I have one dot solid on the fuel guage, I can add at least 9 gallons (3 left in tank) which for me would be 120 miles, having driven about 350 miles on that tank. That's assuming the fuel is all usable, which may not be a good assumption. Is there something about the fuel tank that would make 3 gallons of gas unusable?
    #10 donzoh1, Aug 24, 2020
  11. PA Prius
    PA Prius Active Member
    753
    240
    SE Pennsylvania
    Consider yourself fortunate to get 9 gallons in. I fill within 20 miles after the last pip starts blinking and get in 7.8 -8.0 gallons. My brother drives his about 40,000 year and he runs 200 miles after it starts blinking. I am not ready to do that, but it is a bit annoying to think I am carrying around 4 gallons of unusable gas. Maybe.
  12. donzoh1
    434
    149
    Lenexa, KS
    4 gallons of usable gas weighs around 24 pounds so I don't mind carrying that around. I see the fuel stop as an inconvenience so I try to minimize them. Of course, running the Prius out of gas can be a large inconvenience. This seems like a design flaw that wouldn't be that hard to get past. Like, why do you need to add 3 gallons? That's dumb.
  13. dolj
    dolj Senior Member
    7,506
    3,772
    I notice you have a 2012 Prius Plug-in Advance. It doesn't sound right, but you've tagged onto a Gen 2 thread and the Gen 2 has the fuel tank bladder to contend with which your Gen 1 PiP does not. Maybe consider posting is a PiP forum to explore your issues.
  14. sam spade 2
    7,035
    2,782
    2017 Prius c
    YOU can "get past" it however you please.
    YOU are in total control.
    Now that you know how it works, YOU can let it go as long as you please before filling.
    YOU can be as DUMB as you please.
    Let it go until it sputters and then start looking for fuel.:eek:
    Find something important to worry about.
    THIS certainly isn't.
  15. PA Prius
    753
    240
    SE Pennsylvania
    True, the bladder is a Gen 2 issue. I was hoping the "missing gas" would be better resolved in with Gen 3. In my Gen 2 could only consistently fill with 7.2 gallons, so I suppose I should be grateful for the added .8 gallons in the Gen 3!
  16. lpf
    lpf Member
    113
    33
    Greece
    I don't know what the bladder is. Can you explain? Here in Europe Gen2 fills with 46 liters, 12.1 US gallons. So at the last dot indication, there are 5-7 liters remaining in the tank.
  17. PA Prius
    753
    240
    SE Pennsylvania
    The "bladder" is an expansion chamber in the gas tank. I don't believe it was included on the European versions.
    lpf likes this.
  18. bisco
    48,979
    doesn't pip only hold 10 gallons?
    i always get 8 in when the last pip blinks. you can use the other two if you're brave, but i would only in emergency.
    i may not fill up right away, but i will wait until i reach my favorite watering hole.
  19. donzoh1
    434
    149
    Lenexa, KS
    I don't think it's DUMB to want to know how much farther my car can actually go before filling up. My other car tells me in real time how much farther it can go...in miles. And, it doesn't require 3 gallons to restart. I like much of the Prius. But, the 3 gallon thing is DUMB. The idea that if I add 2 and then try to start...then I need to add 3 more before another attempt is also DUMB. Not sure whether the 3 gallon rule is covered in the Owner's Manual. Either way, it's DUMB. I'm keeping the Prius at least for now. That part of it is still DUMB.
  20. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    You are unlikely to change the behavior of a 16 year old car.
    I give you the facts as I understand them, so your ownership goes as smoothly as possible.
    (I think at times I am the dumb one for trying to warn you about the drawbacks to your car)
    “There are three kinds of men: the one who learns by reading, the few who learn by observation, and the rest of them who have to pee on an electric fence for themselves.” (Will Rogers)
    #20 JimboPalmer, Aug 26, 2020
    lpf likes this.
