Low fuel warning came on with 3 gallons still in the tank
Discussion in 'Gen 2 Prius Main Forum' started by Soylent, Sep 12, 2006.
  1. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(Soylent @ Sep 12 2006, 01:14 PM) [snapback]318535[/snapback]</div>
    I visualize it as a balloon in a bottle. Not a normal balloon, but one that doesn't give that much or gets stiff when cold.
  2. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    <div class='quotetop'>QUOTE(Soylent @ Sep 12 2006, 04:14 PM) [snapback]318535[/snapback]</div>
    [attachmentid=4992]
    [attachmentid=4994]
    [attachmentid=4995]
  3. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    Here you go:
    [attachmentid=4998]
    At 57, it really hasn't been troubling me that much, maybe once a night. However, the Prius has a system like this:
    [attachmentid=4997]
    - Tom
  4. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    So, you are believing you have 10.6 gallons at 14F and 11.9 gallons at 14.1F. :)
    Ken@Japan
  5. Tideland Prius
    16,553
    <div class='quotetop'>QUOTE(Tempus @ Sep 12 2006, 04:32 PM) [snapback]318638[/snapback]</div>
    so if I'm interpreting correctly, some of the lines are INSIDE the tank and therefore when the bladder expands, it can't expand right to the walls of the tank in some places because of these lines (which I presume are between the bladder and the metal tank). If that's the case, that'll explain why most of us can't reach that 11.9 gallon (although some of us can). If the bladder wasn't there, that means those lines would be submerged in fuel, right?
  6. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    One further data point I've read. If you do run out, you will have to add at least three gallons before the fuel is picked up. Appearantly, when driving it sloshes around and picks up that much more than when stopped. Presumably it collects in the sub-tank where the pump is.
    Usually this type of design it intended to perform two functions:
    First, it keeps fuel around the pump, already posted why (cooling of the pump).
    Second, any water or dirt that gets in will stay in the bottom of the tank, not to be picked up by the pump.
  7. mcbrunnhilde
    mcbrunnhilde Opera singin' Prius nut!
    619
    26
    <div class='quotetop'>QUOTE(Soylent @ Sep 12 2006, 12:46 PM) [snapback]318522[/snapback]</div>
    EVERY PUMP NOZZLE IS DIFFERENT! Even at the same station there can be a wide variation in when the nozzle clicks off. Yes, you have mild weather in Florida and the bladder wouldn't shrink much, but the computer sensors in your car (the ones that make the gas gauge start blinking) are going to be much more accurate than the click-off calibration on a gas station's pump.
  8. Soylent
    Soylent The v isn't a station wagon! It's just big boned
    443
    Fort Lauderdale, Florida
    2013 Prius v wagon
    <div class='quotetop'>QUOTE(ken1784 @ Sep 12 2006, 09:10 PM) [snapback]318687[/snapback]</div>
    No you are going from one extreme to another. It's 90 degrees here in Miami every day. That's 32 C. Tell me, how much does it decrease at that temperature?
    <div class='quotetop'>QUOTE(Tom_06 @ Sep 12 2006, 07:44 PM) [snapback]318643[/snapback]</div>
    LOL that made me laugh, thanks Tom
    Thanks for that diagram, guys. I'm not sure why they did it that way, but I see lots of places fuel can hide.
  9. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(Soylent @ Sep 14 2006, 03:57 AM) [snapback]319056[/snapback]</div>
    No one knows.
    Anyway, your comments on the top of this thread, "I still had exactly 3 gallons left." is not correct as evryone comments.
    Ken@Japan
  10. KTPhil
    KTPhil Active Member
    1,379
    All you have to visualize is yourself walking a few miles with a gas can and you have your answer.
