Low fuel warning light on v?
Discussion in 'Prius v Main Forum' started by JimCaldwell, Oct 14, 2012.
  1. JimCaldwell
    JimCaldwell Junior Member
    Maryland
    I seem to remember a low fuel warning light coming on when I first got my v. Now I have none, even on startup. Could one kind soul verify that such a warning lamp exists? TIA
    ADR6400L ? 2
    52,848
    do not know about the v, but on my gen II and pip, the last pip starts flashing and there is a single very soft beep with about 2 gallons left. no warning light.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,096
    6,962
    Texas Hill Country
    Yes usually when I get to a range of 20 miles or so.
  4. rcturner
    rcturner Junior Member
    53
    The v does have a low fuel indicator. It comes on when the range is down to about 10 miles. It is next to the fuel gage, the first bar.
  5. rcturner
    53
    The low fuel light does not come on at startup. I believe it looks like a little gas pump but, I haven't seen it in a long time so I could be wrong. When it comes on, you won't miss it. You must let you range go down to about 10 miles to get it to light. My dealer didn't believe there was one based on the information they had.
  6. Keiichi
    Keiichi Active Member
    808
    79
    Goleta
    Confirmed. I ran my gas tank fairly low and saw an orange Fuel Indicator next to the last bar of the tank and I was under 15 miles. It does not light up when you start the car.
  7. bassmanxu
    bassmanxu New Member
    Hey all, new v owner here. Does anyone know the fuel capacity once the indicator is about to reach zero? Is it something similar to a traditional gauge where 'E' really means there is a gallon or two left? Or does zero mean you are in imminent danger of running out of gas? Thanks!
  8. rjparker
    11,096
    6,962
    Texas Hill Country
    Usually low fuel comes on when the tank needs a maximum of 10.5 gallons of the 11.9 capacity.
    bassmanxu likes this.
  9. bassmanxu
    Thanks - good to know!
  10. JimCaldwell
    Maryland
    I ran my fuel down while watching the range remaining.
    The range was 27 miles when the fuel gage went from 2 bars to 1, 17 miles when the low fuel warning came on, and when I filled the tank @15 miles left, it would only take 9.9 gallons.
    ADR6400L ? 2
  11. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    For Canadian reference, I let my tank run down till the fuel light came on last night. 25km left on the range indicator and the low fuel light came on. Filled up with 15km left showing on the range and it took 38 liters(45 liter tank?).
  12. btcompute
    btcompute Junior Member
    46
    Central NH
    Mine came on last week for the first time. It came on just as I was pulling into a gas station. The dashboard said I had about 15 - 20 miles of gas left. Don't recall the exact number. I filled the tank and it only took 9.9 gals. If the tank is actually 11.9, then I still had 2 gals left and over 100 mi.(my overall average is about 50.5). 2 gallons left when the light comes on is consistent with other cars I have owned.
  13. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Today was my first day to see one pip, then the low fuel light with 10 miles left. (orange gas pump across from E, like the white pump across from F) I was down to 4 miles left, it took 9.985 US gallons.
  14. umichioe
    umichioe Junior Member
    77
    I filled up couple nights ago with 10.5 gallons. But no low fuel light before the fill up.
  15. n0na
    n0na Junior Member
    88
    WA
    My warning light came on when the dashboard "range" indicator said I had 14 miles left. I drove 2 more miles and then was able to squeeze 9.9 gallons of gas into the tank. It's probably safest to simply assume the car holds a maximum of 10 gallons, rather than the advertised 11.9 gallons. I'd be interested to hear from someone who ran the car dry and how many gallons it took to fill it up.
  16. Smoter
    Smoter Junior Member
    Ontario, Canada
    I drove mine about 5 km past the "0 Km" remaining on the range indicator.
    When I filled it up I was able to put 40L in it.
    I wouldn't want to drive too much past "0".
  17. rcturner
    53
    Here is a picture of the little orange low fuel light. There was also a "ding" when it came on. Needed 10.006 gallons to fill the tank.
