Low gas caused engine failure P0A0F & P3190??
Discussion in 'Gen 2 Prius Main Forum' started by spikespal, Nov 8, 2011.
  1. spikespal
    spikespal New Member
    Tulsa
    I took my 2008 Prius to Jiffy Lube to have oil changed. When driving away, I made it about one block and all warning lights came on: Master Warning, Hybrid System Warning, Brake System Warning, Malfunction, etc. I pulled the car over and stopped. I started the car again, lights still there - drove 2 blocks back to Jiffy Lube and lost momentum about one block away, with pedal to floor, I could drive about 5 miles an hour into the bay. They looked at it for about 30 minutes and claimed I had bird seed that dropped under the air filter.... I said "goodbye" called AAA and had it towed to my dealer. They said it was because air had entered the system due to my being low on fuel. I have never heard of being low on fuel and it causing the car to shut down nor did I ever get a warning of low gas, still on one bar. Each time I restarted the car at Jiffy Lube, it started fine, drove forward or backward, then lost momentum again. Still no warning of being out of gas. The ticket from the dealer states:
    "Vehicle low on fuel causing ECU to shut down fuel injectors when engine started to misfire. Found codes P0A0F, P3190 in system. Added 5 gallons of fuel and reset ECU."
    Could Jiffy Lube have done something in changing oil or can being low on gas seriously cause a meltdown?!!
  2. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    I have not heard of this and I regularly run my 2010 down very low on fuel with no problems, as I have always done with past cars. I am sure some of the knowledgeable folks on this site will have more to say, especially since you have provided the codes.
  3. JimboPalmer
    12,470
    6,871
    Greenwood MS USA
    P3190 “Poor Engine Power,” and P0A0F “Engine Failed To Start.”
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Sounds like you ran out of gas. What was the gauge reading when you left 'Iffy Lube'?
    PriusGuy32 likes this.
  5. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    This is an engine oil overfill.
  6. djras
    djras New Member
    32
    Victorville, CA
    This sounds like what happened when I did get REALLY low in fuel. The day San Diego lost power I had expected to fill-up by work, but no power to run the pumps. On the way home the low fuel warning alert came on, but from my mileage I figured I still should have almost 2 gallons left (80-90 miles). About 30 miles later the engine shut off on the freeway. I coasted down the next offramp and into a shopping center parking lot. Turned everything off. It started back up, but had "!" warning on dash. Crawled at very low speed to gas station a block away. Filled with 10.8 gallons (523 miles - 48.5 MPG), warning went away and car has run fine since.
  7. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    The low fuel warning is fairly subtle. I'm guessing that you may have just missed the little pipe flashing. If you swear up and down that it was not flashing then you can always have the dealer check your gauge and sensor. Sorry you got stuck with a bill.
  8. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    Low fuel is a red herring here folks. This was engine oil overfill. Come on, this IS Jiffy Lube that we are talking about here!
    Data Daedalus and dave77 like this.
  9. fuzzy1
    10,272
    Readers -- note that this is an extension of OP's posts yesterday: Reading the gas gauge.
    My brief search for these codes, here and outside PC, found multiple cases of oil overfill, out of fuel, dirty MAF, and some other claimed causes.
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Exactly. Why do we need two threads for this?
    Tom
  11. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    It would have to be seriously overfilled. I've had mine filled half an inch over the full dot and suffered no ill effects. Maybe my engine is just a pig? :)
  12. Patrick Wong
    18,200
    6,479
    Yes, seriously, if the car is low on gas then the engine will not run. I hope this is not a big surprise.
    Note that the dealer service invoice says nothing about an engine oil overfill situation. Unless you believe the Toyota dealer tech is trying to make Jiffy Lube look good, I would conclude that the OP had an out-of-gas situation.
  13. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Could it be that they didn't switch the car off when changing the oil, the engine fired up when oil had been drained and new oil hadn't been put it causing engine damage?
    It wouldn't be the first time this has happened where somewhere isn't used to dealing with the Prius.
  14. Patrick Wong
    18,200
    6,479
    That would be plausible if the dealer tech noted permanent engine damage due to a lubrication failure. So far, that has not been reported by the OP.
  15. Chazmann
    Chazmann Junior Member
    Los Angeles
    2020 Prius Prime
    Did the OP ever answered it?
    So, actually he ran out of gas and he called it a meltdown?
  16. spikespal
    Tulsa
    still one bar and no warning of low fuel.
  17. spikespal
    Tulsa
    Pardon.
  18. spikespal
    Tulsa
    thanks, I never had any change in the lights until failure. I watch them carefully.
  19. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Ok now you're scaring me. :eek: I'd never thought of that one before.
    But seriously in this case being low on fuel is the most likely situation. They added fuel and it fixed the problem, that seems pretty straight forward to me. Also, this wouldn't be the first time someone had reported running out of fuel with one bar remaining on the "guess" gauge.
  20. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    As someone suggested earlier maybe the gas gauge needs re-calibration.
