Low gas indicater and Beep?
Discussion in 'Gen 4 Prius Technical Discussion' started by PriusRoadWarrior, Apr 15, 2017.
  1. PriusRoadWarrior
    76
    16
    Wisconsin
    I have noticed Toyota didn't improve the low gas indicator very much over the Gen 3 Prius. Now you get a little gas pump indicator BUT I don't get a beep. I have purposely brought my gas level down twice to see what happens. My Gen 4 2017 DOES NOT beep with low fuel. I have 1500 miles on it, is this the way it is supposed to be or should I get a beep. BTW, when I tank immediately thereafter getting the symbol, I end up putting in 10.2 gallons, so you have at least one gallon left.
    RCO likes this.
  2. Prodigyplace
    12,717
    11,849
    Central Virginia
    Have you checked the manual under Customizations?
    I know @bwilson4web ran his Prime out once. Perhaps he can relate his experience.
    RCO likes this.
  3. bwilson4web
    16,540
    No beep in the Prime either. Nor is there a beep in the BMW i3-REx.
    RCO likes this.
  4. Prodigyplace
    12,717
    11,849
    Central Virginia
    The owner's manual clearly shows which warning lights have buzzers associated with them. It also says the light comes on when there is 1.7 gallons or less. No guessing needed.
    People need to learn research skills in order to survive these days. There is a reason Toyota provides an owners manual with the vehicle.
    GT4Prius, RCO, pakitt and 2 others like this.
  5. bisco
    52,863
    i can't believe, with all the beeping these cars do, that they eliminated the one beep i wanted more of, and LOUDER!:mad:
    RCO and Data Daedalus like this.
  6. PriusRoadWarrior
    76
    16
    Wisconsin
    I agree, with all the beeping of lane changing, seat belt and door alarms, I would like a 5 beep warning for low gas. The engineers blew this one and I hope they can do a upgrade on the software in the future.
    HPrimeAdvanced, RCO and Data Daedalus like this.
  7. bisco
    52,863
    and then a reminder beep every so many miles. doesn't the gen 4 have some message on the display?
  8. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I don't think mine beeped either - warning light, but I thought it changed the TRIP meter to "Distance to Empty" - or am I thinking of my last car. Whatever it did, I thought it was quite obvious it was telling me I needed fuel.
    Data Daedalus likes this.
  9. Mendel Leisk
    42,355
    I'm fine with gas gauge, the 8 or so pips. Seriously, don't understand this need for anything more.
  10. Tideland Prius
    16,681
    I don't recall any other car beeping. I think the beep for the low fuel was unique to the Prius (and I'm sure a few other cars with digital IPs) because the Gen 2 and 3 Prii didn't have the orange/amber/yellow LOW FUEL icon; they only had a blinking pip so the beep was meant to catch your attention since it didn't have the standard yellow icon.
  11. Ferrarilover
    Ferrarilover Active Member
    185
    168
    Manchester, UK
    I have in a Citroen and it beeps when the warning light comes on and hen beeps again every once in a while to remind me. Probably every 15 mins or something.
    iPhone ?
    HPrimeAdvanced, RCO, bisco and 2 others like this.
  12. alanclarkeau
    7,045
    7,593
    My (Euro) Fords (Fiesta and Focus) did that too - at 80 or 100km from empty, beep, and take over the small screen which normally displayed TRIP and Temp - or instant MPG - and replace it with "Distance To Empty" - you could switch it back OK, but every time you started the car, it would beep again and revert to "DTE" again.
  13. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    I have found the piercing BEEEEP fuel depletion warning in my Prius Gen II invaluable. I normally always keep an eye on my fuel gauge anyway, but there are moments when you're concentrating on piloting your Prius and might completely forget you're running out. One might even suffer the occasional (somewhat embarrassing and cringeworthy named "senior moment"). Ergo, any new versions of the Prius should have more visual and audio aids to warn of impending fuel depletion.
    I for one would applaud my Prius II piping up every 5 to 10 minutes, and verbally advising me that my fuel is running out, and I need to find a fuel station immediately.
    It won't do that of course, but I would expect the latest models to have this option onboard - preferably with customisations available.
    iPhone ?
    HPrimeAdvanced and bisco like this.
  14. Prodigyplace
    12,717
    11,849
    Central Virginia
    Then the warning lights need to be in front of the driver. Not the non-existent passenger.
    RCO likes this.
  15. alanclarkeau
    7,045
    7,593
    Yep, I won't own up to a "Senior Moment" either - but I don't mind a "Seniors Discount"!!!!
    I do object to them giving a "Seniors Discount" without asking for proof, though - it'd be different if I looked old:whistle:.
  16. Tideland Prius
    16,681
    Isn't it? It's left of the speedo, as far left as it's physically possible. (under the left indicator and high beam icons)
  17. Prodigyplace
    12,717
    11,849
    Central Virginia
    My warning lights are to the right of the MID screen.
    RCO likes this.
  18. Tideland Prius
    16,681
  19. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    Gen3 had a single beep when the fuel gauge was showing empty (or one bar) and it would beep each time you turned on the car.
    In the gen4 there is nothing like it, except the mute yellow icon showing up silently. And when the (pretty much useless) DTE goes to zero (which it is not when the fuel icon shows up, if I remember correctly), no beep either.
    The fuel gauge also keeps its yellow color all the way down to zero.
    Some better form of reminder about low fuel in the gen4 would be appreciated.
    Though I have to admit that I am never surprised when the yellow icon is showing up, because I know well in advance by seeing the fuel gauge and how many km already driven that I need to fuel up soon before any light comes on up on the dashboard.
    Data Daedalus and alanclarkeau like this.
  20. Mendel Leisk
    42,355
    Maybe an animation? Of a little guy trudging along with gas can? (n)
