Low idle for a second or two upon startup?
Discussion in 'Gen 3 Prius Technical Discussion' started by 462disco, Jun 12, 2024.
  1. 462disco
    462disco Junior Member
    34
    17
    Socal
    2013, headgasket replaced, EGR, injectors, intake manifold all cleaned.
    Upon startup after sitting for a few days, idle will very slightly stumble and sit at 800rpm for a second, then jump to the normal 1200rpm.
    No intake can VVT rattle.
    Any startup after that does the regular high idle smoothly.
    Is this normal?
  2. Mendel Leisk
    42,289
    At what miles was the head gasket replaced, and what's the miles now?
  3. 462disco
    34
    17
    Socal
    145,000. Miles now are 145,020
    Just replaced 20 miles ago
  4. Mendel Leisk
    42,289
    So hot on the heels of a big repair, good to know. Lot of things may have been missed. Shop did the repair?
  5. 462disco
    34
    17
    Socal
    Did it myself. Very meticulous with everything- I’ll drive it another few hundred miles and recheck if the problem persists.
    Brian1954 and Mendel Leisk like this.
