Low Idle/Intermittent Engine Idle :(
Discussion in 'Gen 2 Prius Main Forum' started by tonyBBQ, Jun 19, 2017.
  1. tonyBBQ
    tonyBBQ Junior Member
    Portland OR
    Hey everyone,
    I went to get an oil change today at a place that's about one notch above Jiffy Lube.
    I bought Mobil 1 5-30 and a Mobil 1 oil filter because I planned to change it myself as I have done in the past. However, I was too cheap to buy new car ramps (I moved and didn't bring my old ones) and I wasn't able to find a good curb close to my apartment to pull up on. (which has worked well before!)
    OK.
    So I get the oil changed and they show me the air filter and I decline a new one blah blah blah.
    When I eventually leave and drive down the road a ways I notice that the ICE turns off a lot faster than it used to while driving. However, sometimes at a complete stop it would keep running at a very low idle and it didn't show up on the display that the engine was still on.
    I also messed with the engine idle while in park. I would step on the gas to turn the ICE on and it would idle for about three seconds, idle at a lower rpm, then turn off. it just piddled out!
    It seems like there is a vacuum leak somewhere, but idk how in the heck they could have screwed something up this bad.
    Tomorrow morning I'm taking it to the dealer (reluctantly, because I am broke) to see if it trips a code.
    I'm supposed to drive four hours tomorrow for a family emergency and not sure if I will be able to because of this....
    Any tips?
    Thank you!
    Brandon
    Ajourney101 likes this.
    49,385
    is the oil level ok?
  3. CooCooCaChoo
    CooCooCaChoo Senior Member
    899
    501
    Cow-lee-fornia
    2023 Prius
    It sounds almost like normal operation. Did they put the air filter back in after showing it to you?
    Even after owning my Gen 2 for over two years, I still notice new things that it does that is normal for a Prius.
    For instance. I used to remember being able to hear the ICE when it runs, even though it was barely audible. Today, when the ICE comes on and turns off, I can barely notice nor hear it and wonder if it has always been like that or I am just imagining being able to hear and feel it in the past.
