Low in the snow
Discussion in 'Gen 4 Prius Main Forum' started by goldfinger, Dec 14, 2016.
  1. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    The gen 4 is definitely lower than my gen 2.
    Mendel Leisk and RCO like this.
  2. Absolu22
    Absolu22 Junior Member
    28
    61
    The Prius got a similar ground clearance (5.7'') than many other cars, almost the same as my neighbour BMW 328i (5.5'') and the exact same for Subaru Impreza (5.7'').
    Yes it's still low, but that's probably fine 99.5% of the time, and I am glad 99.5% of the time that I got rid of my SUV!
    The center of mass being lower, it drives better in slippery snowy icy conditions..
    In the end, what's make the difference is the winter tires.
    I am not afraid to take my Blizzard Pearl in a snow storm!
    Prodigyplace, RCO and MichelleStone like this.
  3. MichelleStone
    MichelleStone Senior Member
    549
    819
    Mariposa, CA
    The snow is deep with you.
  4. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    Were you stuck, with the wheels off the ground?
    RCO likes this.
  5. GTBaker
    GTBaker Member
    45
    ----Canada----
    Looks like the bottom is at least smooth not to hang up.
  6. goldfinger
    535
    403
    Buffalo
    I had to back up a couple feet and then plow on.
    That sure is handy. I may start a plow service.
    RCO likes this.
  7. Mendel Leisk
    42,384
    I nearly got stuck Wednesday (3rd gen): plowed my way into a parking spot where the snow was a bit more than 8", and crusty. With a bit of back-and-forth, trying different directions of the front wheels also, I finally was able to extricate myself.
    It doesn't take a lot of depth, especially if it's getting packed. This was with 15" X-Ice tires too.
    #7 Mendel Leisk, Dec 17, 2016
    RCO likes this.
  8. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Does any snow get trapped in the front fascia? Or plowed by the grill? Seems like packed snow would damage the front end.
  9. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    The gen 2 +3 have 5.7" of clearance but the gen4 has 4.9", its a big difference
    Felt, Coast Cruiser and Absolu22 like this.
  10. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Thankyou for clearing the street for me. ;)
    RCO likes this.
  11. Absolu22
    28
    61
    I would be very careful driving around pack snow. Perhaps it is less of an issue when you back the car as the rear end looks slightly higher.
    Coast Cruiser likes this.
  12. Mendel Leisk
    42,384
    Looks like you can still put foam pipe insulation in the front grill, two 1.5" OD tubes by the looks of it. That'll help some with snow I think, fill the voids, make the front more uniform.
    I've only got one tube so far on ours (3rd gen) this year (similarly, on lower grill), and considering temps are dropping to -8C overnight, daytime highs still below freezing, I should probably put in the second one. Temps are supposed to moderate though, so maybe I'll do nothing.
  13. Coast Cruiser
    2,267
    2,571
    4.9 inches. Thanks. That's why I keep scraping when going down or up some driveways. (Even slowly).
  14. Prodigyplace
    12,720
    11,852
    Central Virginia
    Do NOT use foam pipe on a Gen 4. Let the active shutters do their job!
    Absolu22, RCO and Mendel Leisk like this.
  15. Mendel Leisk
    42,384
    Yes, my bad.
    Absolu22, RCO and Coast Cruiser like this.
  16. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    And that's why I keep my gen 2. I can destroy it and I don't care!
