Low Mileage on PiP basic 2012
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PriusPlug, Jan 1, 2013.
  1. John H
    John H Senior Member
    2,208
    558
    if you know what time you are departing, you should try to time the charge to finish about 15 minutes before departure for best results. this will have the battery still warmed from the charging.
  2. PriusPlug
    PriusPlug Junior Member
    32
    I can promise you that I will post the results of all the suggestions after trying them out for few days. One thing we started doing today is to switch off the heater as was suggested yesterday. I was expecting more like 50+ mpg at the minimum instead of 40's like i used to get in my prius 06 with heater and everything going. In the bottom of this thread uploaded the pictures of EV miles ~ HV miles for the month and the day. She does take short trips during lunch hours to the mall that I know as I can see the charges on the credit card :).
    JMD likes this.
  3. PriusPlug
    32
    This is something I will have to try by changing the timer. Dealer told me that we should charge it between 1 am and 4 am for lowest cost of charging so we are doing that. Wife goes to work at around 8 am. So there is a 4 hour gap between the charging and actual drive. The garage is also not heated so it is quite cold in the nite.
  4. John H
    2,208
    558
    if you are on a TOU rate plan with the utility, see what times are "offpeak". you can do most of the charging during "offpeak" and then do something like the last 15 minutes of charging just before departure to warm up the battery a little. I don't know how to stop/start charging on a PiP so someone else here might be able to help. with this colder weather I try to do a remote start while plugged in about 10 minutes before departure and that seems to work well for my car.
  5. PriusPlug
    32
    Will check with the utility company tomorrow to see the off-peak times and rates. Haven't done that yet. Just following dealer's advice so far to charge it between 1 and 4 am.
  6. bisco
    52,885
    it's not going to make a big enough difference to make it worth spending more for electricity.
    lensovet likes this.
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    It is getting about 100 MPGe (337.5 Wh/mi) on electric miles and 46 MPG on gas miles.
    That's not bad but sure could improve. The biggest concern why all the EV miles were not utilized. That's why your EV ratio is low.
    Does she switch to HV mode? Perhaps she flocks on the accelerator often that ICE doesn't get much chance to shutdown?
    On that trip 4 miles were on EV and 4.2 miles remaining so, she would have gotten 8.2 miles.
    JMD and lensovet like this.
  8. John H
    2,208
    558
    It looks like most PiP drivers are running in the 4-6 cents per mile range. if starting with a warm battery gets you another mile of EV , would it be worth more than 10-15 minutes (.3 kWh) of regular rate electricity vs offpeak rate ?
  9. lensovet
    2,615
    496
    Burlington, NJ
    OP is in NJ. If he doesn't know about off-peak hours, he's probably not on the TOU plan.
    PriusPlug, thanks for the pictures, they are very informative. Namely, why is she not using the full EV range? Make sure she's not pressing the HV button and consequently artificially deflating fuel economy.
    Never listen to car salesmen.
    Also, what John is suggesting is physically impossible. Regardless of which timer you use, the car will always charge to full. The only way to prevent this is to plug in the EVSE into a timer outlet and have that shut off before the charge is complete. Please consult the FAQ, which covers this.
    Also, from anecdotal evidence on the forum here, it doesn't appear that having the charge complete just before departure makes much of a difference. YMMV, of course.
  10. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    That's a head scratcher. I'd be challenged to figure out how to not use up the EV miles. As long as you leave it in "EV Mode" (as illustrated), you'll get a boost from the electricity even when the engine runs.
    You may be able to fight the system, forcing the engine to frequently run with heavy heater use and acceleration.
    mmmodem likes this.
  11. John H
    2,208
    558
    That's a shame. What some people do is define two offpeak periods with one starting just before their regular departure time and then select departure based charging and restricte to offpeak periods, or just schedule a remote start to precondition the vehicle 10 minutes before their regular departure time.
  12. For your wife's schedule, start: at 0500 and stop: at 0800. The car accepts one or the other, but not both commands. Salesman will tell you anything and act like authorities. Typical driving transitions for most of us is: Charge to full, drive EV to start, when engine comes on, just go along with it and warm up the interior, the engine will shut off after 3-4 minutes. Then switch back to EV and use as much EV as possible. I deliberately leave .5 to 1 mile, that way when you return to HV those numbers can be a bit increased by charging (regeneration). Maybe while your wife is at the mall, there may be a charger there. Then she may have enough to drive home in EV
  13. 3PriusMike
    3,101
    2,421
    Silicon Valley
    First...I'd pay no attention to what the salesman says. Second, I'd be surprised if you have TOU billing and don't know it. Third, it would be odd for the TOU rate to not be the same until 8am.
    Mike
    Rebound and lensovet like this.
  14. lensovet
    2,615
    496
    Burlington, NJ
    I guess on the advanced model you MIGHT be able to do something like this since it supports remote charging. Of course if you're in an underground garage with no service, this might be difficult.
  15. bisco
    52,885
    if the rates are the same, i would finish charging just before leaving. that's what i try to do, although, the times it has sat cold for 4-8 hours, i haven't noticed a range difference. it might be better for the battery tho.
  16. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Not driving in EV mode is the only way I can think of to not use up EV range. Are you sure she isn't pressing the EV mode button when she drives off?
    I had a friend who would always press the O/D button to switch off overdrive in her Lexus when she starts up. I asked her why she enjoys low gas mileage and she said that's what the salesman told her to do to avoid overheating the engine. I tried to convince her otherwise but she said she'd rather trust the dealer.
  17. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    PiP always start in EV mode by default (with EV miles, charged). You don't need to hit the EV/HV button. If you do, you'll be in HV mode.
    The biggest challenge with communication is the illusion that it has taken place -- George Bernard Shaw.
    Rebound and mmmodem like this.
  18. PriusPlug
    32
    Latest update: Last 3 days missus drove the car with heater/fan turned off. She used the seat heater instead. I can now see good improvement in EV miles usage. In 3 days out of 56 miles, 24 miles were EV and 32 were HV. When I started monitoring EV miles were in 20% range. Now it is 42%. In the cumulative monthly mpg chart, for the month of Jan i am now seeing close to 90~100 MPG. Earlier it was in 50 MPG range.
    So it seems turning of the heater/fan has a big effect on overall MPG. Bonus is that there are no complains about having to use the seat heater instead of regular heater/fan in the car. Have not altered the overnite charging time so that still remains at 1 ~ 4 am. I will try to call the utility company next week find out about the rates. Then will experiment with charge timing also some time next week.
    Thanks for all the suggestions/inputs on this topic. Much appreciated.
    retired4999, JMD, lensovet and 3 others like this.
  19. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Great to see those new results. Just curious, what temp was the heater set to?
  20. lensovet
    2,615
    496
    Burlington, NJ
    i'm really tempted to add this to the FAQ. Something like "Q: I charge every night and yet am still seeing only 50 mpg. What's wrong? A: Using the heater will turn on the ICE, even if you have a full charge. Stop using the heater and use the seat heaters on HI instead."
