Low mileage tune up suggestions
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Pdaddy, Aug 26, 2018.
  1. Pdaddy
    Pdaddy Member
    160
    49
    I have a 2010 with 200K miles that has been getting about 8 mpg less for over a year. No change in tire which are LOT. It also sometimes has a rough start in the winter. I changed the plugs last at 140K. Besides the plugs what else should I do to tune up the car? Do the spark plug wires need to be replaced after so long?
    SM-G920V ?
  2. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    200k? Rough start in the morning?
    Save up- plan on a new HV Battery or Head Gasket soon.
    If the plugs were replaced at 140K using the correct ones, the service life should be 120K.
    Raytheeagle likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,523
    Bay Area, California
    2019 Prius Prime
    Egr circuit;).
    I’d look there as low mpg could be due to clogging of the system :(.
    Good luck and keep us posted (y).
    mjoo, tankyuong, bisco and 1 other person like this.
  4. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    200,000 miles is no way in the category of "Low mileage" tune up.
  5. Pdaddy
    Pdaddy Member
    160
    49
    I meant that the car is getting low mpg and inquiring what to tuned up.
    SM-G920V ?
  6. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Cycle the emergency brake to make sure it’s not sticking, grease the brake caliper pins, clean the interior air filter, check the obd2 for codes like a cylinder misfiring, trickle charge the 12v to make sure it’s fully charged, run 40 lbs in the tires, start sourcing a factory fresh traction battery.
  7. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,752
    1,780
    Bay Area
    All of the recommended maintenance can be found in our YouTube channel.
    I would do all of them if you haven’t done them. Fluids, cleaning, lubing etc etc.
