Low miles on 2008 Prius!
Discussion in 'Gen 2 Prius Technical Discussion' started by Iamjo20, Apr 19, 2017.
  1. Iamjo20
    Iamjo20 Member
    259
    Is it correct that due to the fact that my 2008 Prius, having only 28600 miles, will terribly limit the life of the hybrid battery?
    Thank you!
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Yes very much so especially if it has spent its whole life in Florida. BUT....it may be worth it to spend $400 and buy a battery charger/dis charger and see if you can wake it up with a discharge/full charge cycle. It may come alive nicely especially if garaged its whole life.
    But, at that mileage it sure is worth putting a new battery in it if you can buy it right. You'll be good for at least 10 reliable years.
  3. Iamjo20
    Iamjo20 Member
    259
    THANK you for your information! I was unaware that a HYBRID battery could be charged? IF they can be, please advise as to where this product can be purchased....... And, I know of nowhere in my area who will install a new hybrid battery except Toyota :-(
  4. uart
    uart Senior Member
    4,220
    1,212
    Australia
    While low mileage isn't always good for the battery health, it' not necessarily a terrible thing either. Your car has only done about 65 miles per week, but that's enough to keep the battery charged and occasionally cycled.
    I believe that the best predictor of a batteries future health is its current health. What is the current condition of you battery like? Is it running well, no anomalous behavior, no rapid changes between green and purple or vice versa?. If so then your battery has as much chance of a good lifespan (in years) as any other.
    Data Daedalus likes this.
  5. Iamjo20
    Iamjo20 Member
    259
    Thank you! The car is running great---and I have NEVER seen great changes in the colors!
  6. Iamjo20
    Iamjo20 Member
    259
    I also have NEVER heard of a hybrid battery charger--
  7. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    WilDavis likes this.
  8. greasemonkey007
    287
    106
    jeff652, Iamjo20 and WilDavis like this.
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    jeff652 likes this.
  10. Iamjo20
    Iamjo20 Member
    259
    thank you--I will check that out!
  11. Iamjo20
    Iamjo20 Member
    259
    jerrymildred likes this.
  12. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Only hard part to the charger is you have to open the battery case and bolt in the charger lead to the battery side contactor. Its not hard its just time consuming as alot of the rear interior has to be removed to get to the battery. Hybridautomotive charger comes with very good instructions.
    But if your battery is running ok now it will run really good after a full discharge/charge cycle. You can also take a peek at all the battery modules and the bussbars and the nuts & bolts and see if there corroded or not. Do that before you install the charge lead as it may be very corroded or not corroded at all. If very corroded you know the battery will need service soon. Hundreds of posts about the hybrid battery rebuild and pictures of corroded bussbars etc. A car that has sat for a while tends to get corrosion at any battery terminal.
  13. Iamjo20
    Iamjo20 Member
    259
  14. Iamjo20
    Iamjo20 Member
    259
    #14 Iamjo20, Apr 21, 2017
  15. bisco
    52,773
    maybe you should consider selling your battery and buying a used one with higher mileage.:cool:
  16. Iamjo20
    Iamjo20 Member
    259
    bwahahahahahaha
    sadly, i do not like the new Prius generation, I fear all of the white plastic all rattling at the same time-HA! LOVE the C-HR-it handles like a dream and fun---but not only back cloth interior--and no nav system---thnk it is aimed at a specific generation---the price is very reasonable--BUT--a rattle on a test drive--that is no-no
  17. bisco
    52,773
    i know, the '08's are rock solid.
  18. Iamjo20
    Iamjo20 Member
    259
  19. Iamjo20
    Iamjo20 Member
    259
    they are? Why and who says? ;-)
    I am about to get cool new wheels, maybe a new front drivers seat (have NO clue what that would cost)--and keep my car! I cannot find ONE car I like. Only one I may try to see if quieter road noise is C-Max-Energi
  20. ETC(SS)
    7,496
    What's going to limit your battery life is a combination of heat, charge/discharge cycles, and the number of times that the earth goes around the sun.
    Your battery is rated for x many years or x many miles.
    Whichever comes first.
    I would expect however, that if your car is driven weekly and it's not roasting out in the afternoon sun, and unless you live very near the ocean (salt air corrosion) then your battery pack will last probably longer than the house bet, which is (IIRC) 10 years/150,000 miles........
    Maybe a great deal longer!
    Priuses have been known to last longer than 10 years........and run much longer than 150,000 miles.
    ..........whichever comes first. ;)
