Low Mpg after wheel alignment?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Eneder772, Nov 22, 2021.
  1. Eneder772
    Eneder772 Junior Member
    Atlanta, Georgia
    So i was getting an oil change at a toyota dealership when they showed some really bare spots on my tires and suggested a wheel alignment. so i got one but after I left the dealer my mpg consumption wont go above 40...where before it was 46-48 range. Should I continue to wait to see if it goes back up or should i go back to the dealershio?
  2. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Doubtful an alignment would change MPG. Did they rotate the tires at the same time? If they did, and crossed the tires, then the direction of rotation changed on at least two tires, and this can definitely cause lower MPG. Another factor could be tire pressure, if they lowered it from where you had it set.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    This would seem most likely. My dealer lowers the pressure to what's on the door post every time they rotate the tires.
  4. zeng
    zeng Junior Member
    45
    Kuala Lumpur
    Mind sharing the alignment numbers?
    You may have high amount of toes in/out.
    Tire pressure drop has more influence on fuel economy hit than excesssive toes I believe.
  5. vvillovv
    vvillovv Senior Member
    4,332
    1,516
    NY
    Depends on how badly the tires were worn and where the excessive wear was. After an alignment with excessive tire wear, it can be just like putting new tires on the car in that the tires have to re wear into the new alignment, and that takes time. 48 to 40 is pretty big drop, but again, all depends on how bad the tires were worn in the spots the mechanic pointed out. Are you thinking about a new set of tires, possibly? If you're already thinking about going back to the dealer, and possibly thinking about a new set of tires and possibly buying them from the dealer, you could ask your mechanic if new tires might help.
    #5 vvillovv, Nov 23, 2021
  6. douglasjre
    douglasjre Senior Member
    2,205
    736
    Null, NL
    Rotating bald tires to rear and full tread to front puts larger diamer tires in front and pseudo mpg drop
