Low MPG I think?
Discussion in 'Gen 3 Prius Fuel Economy' started by Abdul Hai, Jul 18, 2023.
Tags:
  1. Abdul Hai
    Abdul Hai Junior Member
    Afghanistan
    Hello everyone,
    I have recently bought a prius 2013 gen 3 with 234000 kms on it.
    I am regularly changing the engine oil I am using 0W-20 engine oil have recently changed the transmission fluid used Toyota ATF WS, cleaned the egr and other components.
    The only thing that I haven't cleaned is the MAF sensor because I cannot find the MAF sensor cleaner spray in our country and the form advises that I shouldn't use anything else for cleaning it.
    The fuel that we have here is of low quality it's advertised as A92 but mostly they use A80.
    My normal tire pressure is 40 psi for front and back but when I am going to a place with really bad and bumpy roads then I being it down to 33 psi.
    On average driving not using power mode I get about 17 KM/L, we have a lot of stops and go due to the bad roads and traffic.
    If I drive faster like when I am in a hurry then I get about 13 KM/L.
    I have tested it's batteries and all the workshops says that they are completely ok and no problem with any cells of it.
    So is this ok or is there something wrong with my prius?
    Btw I live in Afghanistan and the car is Japan made.
  2. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    You can use rubbing alcohol to clean it.
  3. Mendel Leisk
    42,376
    I’m not completely sure, but I believe a spray described as “electronic parts cleaner” would be compatible. Basically a safe/effective solvent that leaves no residue, suitable for delicate electronics. Maybe research more though.
    those values converted to US mpg are 40 mpg and 31 respectively.
    52,891
    you're averaging 20km/L mendel? 17 doesn't sound bad on a car with 234,000 kms in afghanistan
  5. Mendel Leisk
    42,376
    Yeah. come to think of it (with 5 liters per 100 km). I agree, a long-in-the-tooth car in Afghanistan conditions.
    @Abdul Hai: I'd guess you're using air condition most of the time; that'll increase fuel consumption.
    Zaza 13 and bisco like this.
  6. Zaza 13
    Zaza 13 Junior Member
    74
    Israel
    I think your car is ok, just u live in to hot conditions, your battery is hot most of your driving time, check your battery fan - if it's clean. try to drive with air conditioner to make your battery cool.
  7. nicoj36
    nicoj36 Active Member
    518
    162
    If you regularly use low-quality fuel, I would advise to use fuel-system cleaner every 2-3 months or so. The prius only has 11-12 gallons and most cleaners can clean more than that so measure it and save leftover for next.
    Also try this reset and see if it helps with your MPG.
    #7 nicoj36, Jul 26, 2023
  8. Abdul Hai
    Afghanistan
    That's true my AC is always on the temp is at low and the fan is 5 or 6 most of the times.
    The outside temperature is around 35C during the day.
    I am cleaning the battery fan regularly it's completely fine and whenever I am driving the AC is on and temp is set to low.
    Can't find good quality fuel system cleaners in here the ones that are available ruins the fuel injectors after using it 2 or 3 times.
    Did the reset disconnected the 12v battery now I am getting about 19km/l under normal driving without reving the engine alot.
    #8 Abdul Hai, Jul 27, 2023
  9. nicoj36
    518
    162
    You need to do the reset on the video. Disconnecting 12v doesn't help.
  10. Mr. F
    Mr. F Active Member
    390
    264
    Washington
    You keep posting this video and mentioning a 'reset'.
    What exactly do you think it resets, and why? Are you aware of any documentation from Toyota that confirms this? More importantly, are you aware of documentation from Toyota that refutes this?
    #10 Mr. F, Jul 28, 2023
    Zaza 13 likes this.
  11. Zaza 13
    74
    Israel
    check your engine air filter, also try to use 5w30, 0w20 is to low for your temoeratures, i use 5w30 liqui moly molygen, engine works very quite and very smooth also in very high temperatures (35 - 40 c).
    any way 5 l/100km I think it's ok. have u ever changed hybrid battery pack on this car?
