Low Rolling Resistance replacement tires: Current List
Discussion in 'Gen 3 Prius Fuel Economy' started by F8L, Apr 17, 2011.
  1. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Yes, it comes in the 205/50/17. I was too tired to update the list with that size and the 175/65/15. :)
    They are indeed heavy. Keep in mind that weight may not play as large a factor as sheer friction. That is why the mpg drop between my 15lbs 17" wheels and the 24lb 17" OEM wheels seem to be the same. :( It will be interesting to see how these work out.
  2. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    List is updated for new Prius v and c sizes. I'll add the Michelin Defender when it becomes available.
    Please note the Energy Saver A/S will be available within a week or two.
  3. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    So which will be the best choice? Energy Saver or Defender? Or the new Yokohama? :cool:
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    These are my predictions...
    MPG = Energy Saver A/S, AVID Ascend, Defender
    Longevity = Defender (90k), AVID Ascend (85k), Energy Saver A/S (65k)
    Price = AVID Ascend or either Michelin if you catch the $70 rebate either way it is only a $26 difference unless you don't get the rebate.
    Performance = Not sure. My money is on the AVID Ascend but until it is tested we won't know. I think the Defender will be the least performing but it's just a guess. The dB Super E-Spec was a great performer for a LRR tire and the Ascend uses some of the same technology.
    You left out the Continental ProContact EcoPlus. It is rated as long wear (80k), is priced low at $80 or so, is a great performer, and is decent for mpg. You can't go wrong with it unless you are looking for the absolute best mpg and treadlife be damned (Energy Saver A/S or EP100).
  5. fwbrc51
    fwbrc51 Junior Member
    61
    Fort Walton Beach / NW Florida
    Is the Ecopia EP422 a better choice than the EP100?
  6. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    No for the following: MPG, wet traction, handling.
    Yes for the following: Treadlife, cold weather, is not being discontinued
  7. fwbrc51
    61
    are the EP422's better than the goodyear integrity tires? I was quite happy with the stock Integrity tires.
  8. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    By a long shot. Integritys may have rated high for dry braking in the Tirerack test but everything else was well below average. Wet braking is downright dangerous!
  9. fwbrc51
    61
    I have no problems with the Integrity, but I can get the EP422 cheaper than the Integrity. If all properties about the 422 are the same or better than the Integrity, then i'll have no problem with the 422.
  10. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Then pull the trigger. :)
  11. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    Has anyone tried the Continental's ProContact with EcoPlus technology? Has 80K warranty and has good reviews at tirerack.
  12. mikesarebetter
    mikesarebetter Junior Member
    53
    south dakota
    i've been trying to find out more on these tires too.. pretty sure they're the ones i'm gonna buy when the time comes but there's so many awesome review of the ecopia's its hard not to buy those instead
  13. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Yes, a lot of people are using them. It ranked very higher with Consumer Reports as well. The Energy Saver A/S will net better mpg but the ProContact is better in all other respects and it is cheaper and may last longer which may balance out the lower gas mileage.
  14. paycee
    paycee Junior Member
    48
    Hi F8L
    Just want to post to try if fuelly worked...
  15. paycee
    48
    It did! thanks! :)
  16. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    NP, my friend. :)
  17. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Yes, I bought a set a few months ago. So far they seem OK. A little better road grip and faster "turn in". MPG has remained about the same as stock. Which would indicate a little better MPG after the tires break-in. The ride has not improved - I still feel every crack in the road.
  18. avery_larry
    avery_larry New Member
    Ames, IA, USA
    Any info on Yokohama AVID Ascend road noise? Also, the UTQG is 800 A B. Should I be worried about the B? (I've lived in Iowa my whole life and NEVER used winter tires.)
  19. avery_larry
    Ames, IA, USA
    . . . And should I be worried that the Continental UTQG is 600 compared to Yokohama's 800?
  20. avery_larry
    Ames, IA, USA
    Oh -- never mind about the "B" rating. I misunderstood what it meant before.
