Low Rolling Resistance replacement tires: Current List
Discussion in 'Gen 3 Prius Fuel Economy' started by F8L, Apr 17, 2011.
  1. Agape
    Agape Member
    378
    Ireland/Eire
    No but I also speak some russian, polish, english, german and bit of one other asian language so I like to browse multi-national forums/sites :)
  2. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    I have oem 15" on my 2012 Prius what shold I expect for the true LIFE of the tire?
  3. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    I replaced my Yokos (I don't know which brand they were) at just under 4 years and 40,000 miles. They weren't bald but looked pretty worn by then and I was starting to not feel safe in wet weather.
  4. Baldbubba
    Baldbubba Member
    142
    27
    in PRIUS down by the river
    I am one that does not want to do research just tell me which to buy I have a 2008 80,000 miles Local tire discount center Told me the right rear is on the secondary rubber I am looking to replace the tire and possibly other rear tire should I replace all four, the vehicle has 80,000 miles on. I'm sure this is the second set of tires that are currently on it I Drive in central Illinois snow and hot weather Very average driver 12 to 15,000 Per year Could you please just give me some ideas on which tire to purchase This is a great forum I have learned many things the prius is the greatest vehicle I have ever owned I've had it now for eight weeks Thanks in advance for all your help. Should I replace two tires or all four. Or just the one that is on the secondary rubber. I am willing to spend the money to get a good tire with my family on board I don't have any questions but I should have purchased. However I don't want to spend money foolishly
  5. RRxing
    RRxing Senior Member
    2,559
    1,835
    NEPA
    I just replaced my OEM Yokos last month with Michelin Defenders. They had almost 53,000 miles on them and would probably have made it through the summer. Of course, YMMV, and everyone else's, too.
  6. MPGnutcase
    579
    114
    Chicago
    53k on OEM's is great I think
  7. PriusRos
    1,973
    218
    Rockville, MD
    All right - this is a short summary of everything I've learned researching (Consumer Reports and many other tire reviews) my last tire purchase and reading this forum. First, you should change all four tires. It makes no sense to just change one or two unless it's obvious that the other two or three are much newer.
    If your primary goal is high gas mileage, Michelin Energy Saver All Season tires are your best bet. They do great in wet weather but snow and ice might be iffy.
    The Michelin Primacy [can't remember the model type but it's been mentioned multiple times in this forum] is probably the best rated all season tire for traction and handling in all sorts of weather as well as for low rolling resistance, but you won't get as high gas mileage (from personal experience).
    Michelin Defender is probably about the same as the Primacy for gas mileage but has a 90,000 mile warranty, which is much higher than the two mentioned above. It's snow and ice rating is about the same as for the Energy Saver.
    All three I mentioned are Michelin because of the Consumer Report ratings and the fact that they are available and on sale at Costco. The Bridgestone Ecopia is another one that's supposed to have good gas mileage but the CR ratings are way down. Of course, a number of other brands have been mentioned in this forum but if you want a quick recommendation, this is it.
    F8L likes this.
  8. Baldbubba
    Baldbubba Member
    142
    27
    thanks for inf .....most every time i have issues with car repairs or purchase ,,, i get taken advantage of
  9. Baldbubba
    Baldbubba Member
    142
    27
    i am setting at discount tire Getting 4 Michelin Defender series put on for $512 out the door! thanks for all the help
  10. milkman44
    milkman44 Active Member
    591
    386
    Ky
    I did the same back in March, now I know to go with the Energy Savers next time.
  11. Baldbubba
    Baldbubba Member
    142
    27
    how much did they cut ur milage?.
  12. PriusRos
    1,973
    218
    Rockville, MD
    Who are you asking?
  13. Baldbubba
    Baldbubba Member
    142
    27
    milkman said he had purchased the same tires i was getting,, he said he would get different ones,, i was wanting to know how much his MPG decreased
  14. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    America's Tire is running their $100 rebate on 4 "best class" tires again! Now is the time to buy if you need. :)
  15. Baldbubba
    Baldbubba Member
    142
    27
    got my michelin defenders for $ 512 out the door got the $100 rebate on the way, Discount tire is great! I just hope they dont eat into my mpg.
    F8L likes this.
  16. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Great price but they will put a dent in your mpg. They last a long time though. :)
  17. Baldbubba
    Baldbubba Member
    142
    27
    how much of a dent? will they put in my mpg,,, just a ballpark figure?
  18. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    3-4mpg initially. Maybe 2-3mpg long term. Just a guess.
  19. Baldbubba
    Baldbubba Member
    142
    27
    i love the ride the give,,, what kind of tire pressure would u keep in them? i have gen 2 ,, 2008. thanks for all ur help
  20. milkman44
    591
    386
    Ky
    That's the hit that I took, like the ride and the miles they will go. For me, the long miles they should get is a one time "good feeling", but it won't make up for the "groan" I get at each fill up.:(
    F8L likes this.
