Low Rolling Resistance replacement tires: Current List
Discussion in 'Gen 3 Prius Fuel Economy' started by F8L, Apr 17, 2011.
  1. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I assume you are referring to the O.E. Ecopia EP422 that come on the Nissan Leaf? Those are different than the aftermarket versions. Much different. The ones that come on the Leaf are terrible!
  2. hill
    9,014
    OH yea
  3. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    While I'm thinking about it, there are not nearly enough rave reviews in this thread for the Michelin Primacy MXV4. With most my driving being in town, and awful Houston streets, I wanted as much cushion as possible. They ride very soft, but with good handling (no wallowing). They are also quiet, after being broken in (seemed like there was of bit of muted wind whistling at first). Not seeing any mileage hit or improvement, but it's kind of hard to tell with my low miles and lots of EV driving. I didn't trust the rain performance of the Michelin Energy Savers. The Primacy had decent rain/snow/ice ratings on tirerack.com (though not as high as the Defender or the ProContact). I thank my wife all the time for hitting that pothole that prompted me to buy all new tires!
    drewhaben likes this.
  4. erch
    erch Junior Member
    Ohio
    I too have the body roll problem with the energy savers, but I get almost 6 mpg better with them than the defenders. I bought defenders when the cAr was new and the mileage dropped about 3 or so mpg from the original tires. Then switched to energy savers and it went up by at least 6 over the original equipment and about 9 over the defenders,
  5. drewhaben
    drewhaben New Member
    Ohio
    Just special ordered the Primacy MXV4, so I appreciate the thumbs up on these tires. ((Note: the Ecopia EP20 that came on my Prius are worthless--terrible in snow; I only have a little over 20k miles and they need to be replaced.))
  6. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    My Ecopia EP20's are excellent in snow, granted they are new! From what I have read you will take a big hit mpg wise , so keep us posted. :) H
  7. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    I put MXV4 tires on my Volt and immediately saw a 10% drop in mpg and EV range from old worn down tires. This has only recovered somewhat after putting 16,000 miles on them. After buying them in somewhat of a rush I did more research and found others here with similar efficiency drops on the Prius.
    While efficiency is a concern, the tires are otherwise excellent. I wanted something quieter than the original Goodyear Fuel MAX tires. The MXV4s also have very good overall test results for summer and winter traction and I haven't seen any of the complaints about sidewall failures or premature wear that you hear about the Ecopia tires. All tires designs make compromises and tradeoffs and you need to choose the tires that best match your own needs.
    In retrospect, I probably should have chosen the Ecopia EP420 given my conservative driving style and desire to maximize mpg and EV range but it's a close call even for me. The MXV4s seem more reliable and will almost certainly wear longer.
  8. Mendel Leisk
    42,275
    Yes, EP20 tread is ok in snow when new. But a different story when down to 5 or 6 32's remaining tread: then they're pretty bad.
  9. drewhaben
    Ohio
    Maybe I'm just a terrible "snow" driver:(.
  10. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    62,500 on my OEM EP20's now; probably will make 70,000. We've done fine in all weather with them, but this is the plains, and I cannot say how they climb on ice/snow.
  11. Mendel Leisk
    42,275
    Once an EP20 gets down to about 6/32" remaining tread depth there is NO lateral treads, nothing but longitudinal grooves. With that set up, I had to get our previous Civic Hybrid down to a tire place for snows, on a morning with a fresh dump, maybe 8". I barely made it out of our unshovelled (downhill sloping) driveway. Once I was on main roads where the stuff was flattened down I could stay mobile, but I was a menace, slip-sliding. It was crazy at the tire place too: they were expecting a plow to come in and clear the lot, but it hadn't made it, LOL.
    I wouldn't entertain all-seasons, with their harder rubber compound and token lateral grooves and siping, for snow use.
  12. Delta Flyer II
    Delta Flyer II Active Member
    547
    248
    69
    Very detailed list….
    Thanks F8L!
    You rock! (y)
  13. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    Hey, I havent been on here in a while but referred back for some info. I replaced my OEM Avid s33d with new continental purecontact. I lost about 8-10 mpg immediately and have not regained the loss after 5000 miles. I was considering the Energy Savers AS and saw that you got them. I realize it has only been about a month, but how do you find the mpg's? Anything unexpected with them? Thanks
  14. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    I got mine about the same time and the only thing I can say about MPGs is that this winter was colder than the last. It's too cold to make a fair comparison.
    I do notice less rolling resistance on my Energy Saver A/S than I had with the Goodyear Integrity(s) and less than I had on my Yokohama Avid Envigor(s) when the tires have warmed up and I'm trying to coast or glide.
    I went from the stock 185/65/15 to 195/65/15 and I'm noticing that it takes more pedal to start off the line due to the increased diameter tire but I'm hoping when the weather warms up the difference won't be as noticeable. I remember someone saying the Energy Savers get stiff below 50F.
    I really need to wait for warm weather to make a fair comparison to the other two sets of tires I've had on this car.
  15. Bob G IA
    Bob G IA Member
    167
    51
    When did you put them on? What air pressure do you have in them?
    My mileage dropped too, but it was because the temperature turned cold right after I got them. On warm days I'm back up in the 53 MPG range.
  16. pmike
    pmike Member
    237
    81
    Central Florida
    Current Promotions and Forms items in Discount Tire Direct store on eBay!
    $408 with free shipping: 4 NEW 195/65-15 GOODYEAR ASSURANCE FUEL MAX 65R R15 TIRES
    $100 instant rebate via eBay and Discount Tire Direct. Use code CMOTORS0314 during eBay check out.
    $40 rebate via online or mail in rebate by Goodyear and Discount Tire Direct. Rebate form and online link available though top link. This rebate up to $100 depending on make and model of tire.
    To further sweeten the deal:
    1% cash back via fatwallet.com.
    2% cash back via a 2% credit card. I have Fidelity Amex and Priceline Visa.
    2% cash back via eBay Bucks: eBay Bucks: Frequently Asked Questions
    I just bought the referenced set for our 2012 Civic LX non-Hybrid with 52k on it now, same size as the ones on the 2013 Prius Two. The Civic came with Firestone Affinity Touring S4 Fuel Fighter. With those it would get 41+ mpg (as reported) at 70mph with cruise control and a/c, Central Florida terrain. The mph is almost dead on and the car reports mpg a little under actual.
  17. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    I'll be interested to see your review.
    I haven't seen anything like a 10% drop. MPG has been about the same as the Goodyear OEM tires for me. e.g., 52 MPG on a recent trip to Galveston, driving 70 to 75 mph. That's about what I did on a long vacation trip on the Goodyears last year (for the gas only portions). I'd be curious to see a carefully controlled comparison of AS to Primacy mpgs.
  18. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    I put the purecontact about 4 months ago. I made the fuel economy comparison based on the last 4 years numbers. The lowest fuel economy I ever got was during winter numbers, never got lower than 47 mpg in 4 years. During summer months I averaged 55-60. Overall FE "never reset trip B" was 55.4mpg. After tire change (and only tire change, no oil or other maint) my FE is hovering around 45-46. Tire pressure was set at installer per vehicle req, I increased to 42-40 but no improvement, so i bumped it up to 48-48 and now 51-50 (max sidewall pressure) still FE has not changed. Either the Avids were excellent for LLR or the purecontacts are not up to par. I considered the Energy Saver A/s or just going with the original Avids. I read that the energy savers provide a better handling and wet traction than the Yoko Avids, i dont want to risk getting the energy savers and then realize that they are not as fuel efficient as the yokos.
  19. dhanson865
    851
    188
    TN, USA
    Went to the Michelin site today and see the new tires coming out next month that presumably are the replacement for the Energy Saver A/S
    They call them Michelin Premier® A/S and they say they'll be available in April. No idea on pricing.
    Premier A/S | Michelin Tires
    For Gen II 15" 205/60/15 is ideal at 842 RPM
    For Gen III 15" 195/65/15 is ideal at 832 RPM
    For Gen II or Gen III 16" 205/55/16 at 836 RPM
    For Gen II or Gen III 17" 205/50R17/XL at 828 RPM
  20. our1vue
    our1vue Member
    313
    58
    NY
    It shows they have a 10 fuel efficiency rating, does that imply it is a LRR tire ? It doesn't say on the web page (unless I missed it)
